Serpent Project 4-X >
Serpent Project 4-X
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree273Likes
Serpent Project 4-X
Last edit by:
Print Wikipost
Old 01-01-2018 | 08:20 PM
  #451
nubs's Avatar
Originally Posted by Jochim_18
This car is a beast you just need to get the right setup and balance of the car for your track.
It's going to be a learning experience for sure.
The next part I need to understand is how the heave an roll dampers work together.
nubs is offline
Old 01-01-2018 | 08:22 PM
  #452
Jochim_18's Avatar
Originally Posted by nubs
Can someone explain to me the equivalent of raising the inner camber link for this car? I am a little confused by the way that the arms connect to the bulkheads.
It will change to roll of the car. If you have the stock setup you need to remove the F/R stiffener. The current kit setup have a high roll center. changing the shims to 2 mm will lower the roll center for more over all mechanical grip.
You need the Vertical top deck, 7 mm short roll ling and the linear suspension.. The car is night and day with this upgrade.
Jochim_18 is offline
Old 01-01-2018 | 08:24 PM
  #453
Jochim_18's Avatar
Heave dumper = controls the weight transfer of the car from front to rear.
Roll Dumper = control the weight transfer of the car from left to right (also act as a sway bar)
If you are raising on asphalt I suggest this setup.
Front/Rear Heave dumper = 2000 CST with 1 hole piston
Front Roll Dumper = 3000 CST 1 hole piston
Rear Roll Dumper = 2000 CST 1 hole piston
FYI: This is a good starting setup for spec classes only. For mod class you want the oil a little harder.
Old 01-02-2018 | 08:34 AM
  #454
nubs's Avatar
These items are on the way.
nubs is offline
Old 01-02-2018 | 08:51 AM
  #455
nubs's Avatar
I found the vertical top deck and the linear suspension upgrade, however, I don't know what the 7mm short roll link is. Is there a specific item on this page that shows that item:
Serpent Model Racing Cars - Product - Project 4X Touringcar EP 1/10 - Optionals
Nevermind, I found it.
edit:
Do I buy two sets (7mm roll damper support) or just for the front roll damper?
nubs is offline
Old 01-02-2018 | 09:28 AM
  #456
FLEXXLUTHER's Avatar
Default knurled caps
got these for easy adjustments on roll damper
FLEXXLUTHER is offline
Old 01-02-2018 | 10:42 AM
  #457
nubs's Avatar
oh that is awesome, where did you find them?
nubs is offline
Old 01-02-2018 | 11:12 AM
  #458
Default SHCOK CAPS
PM me
Old 01-02-2018 | 06:16 PM
  #459
Jochim_18's Avatar
Nice. Few of my buddies will be racing at Stockton this weekend. I just can't make this week.
Old 01-02-2018 | 07:14 PM
  #460
snuvet75's Avatar
What makes you say stock set up has high roll center? Maybe there is a new default set up for EVO I haven't seen? Or maybe you measured them? When I eyeballed, both front and rear had very low roll centers. But I could be wrong cuz it was just eyeballing.
snuvet75 is offline
Old 01-03-2018 | 07:21 PM
  #461
Jochim_18's Avatar
Stock setup use the f/R stiffener for those to fit instruction suggest 3mm shims under the top arm which raise the roll center of the car. by removing it you can drop to 2mm shims to lower the roll center. Changing shims to different thickness under the top arm changes how the car roll side to side. Same basic principles as to any traditional TC.
I'M talking about the 4x not the evo that is coming out.
Old 01-04-2018 | 01:54 AM
  #462
Airwave's Avatar
Originally Posted by FLEXXLUTHER
Attachment 1455771
Attachment 1455772
Are they home-made?
Airwave is offline
Old 01-04-2018 | 08:29 AM
  #463
nubs's Avatar
Anyone know a good place to buy Serpent Model Racing Cars - Product - Roll damper support -7mm carbon 4-X (2). If I try to buy them from Serpent America I have to pay $13 for shipping. I can't seem to find them anywhere but oversees.
nubs is offline
Old 01-04-2018 | 08:30 AM
  #464
Originally Posted by Airwave
Are they home-made?
cnc swiss made
Old 01-04-2018 | 08:59 AM
  #465
snuvet75's Avatar
Nope. You're mistaken. With thinner shims on upper inner arm, the upper arm will be more angled hence you raise RC and dynamic camber.
erchn and DavidNERODease like this.
snuvet75 is offline
