Team Associated F1
#571
I think they could catch on. Especially if they work well on less then perfect pavement. Though I've got a feeling they won't be available till after my racing schedule is over. Even so I'll definitely be buying a set. Maybe they could make mine drivable away from the prepared surface.
#572
Regional Moderator
Compared to other "non low profile" tire its hard to tell if the thinner sidewall provides any benefit.
#573
I have a set when I bought their F1. The fronts arent bad, they are a pretty hard compound but works pretty well in the summer. The rears on the other hand comes in this weird compound, at least for mine, and doesnt provide much grip. The rubber is "blotchy" too, as if they didnt mix the compound that well. The pictures Ive seen of this tire on the internet looks nothing like mine, so i highly suspect theres a manufacturing problem.
#575
Volante F1
Other than the videos from Asia, who is testing these? Are they even final production units or is this just a hype video and this a proof of concept test? There is only info on Facebook. Their own website has Nnnnothing! Everyone is having a stroke over something we can't even order. If you have some to test, how did you get them and under what restrictions?
#576
Nobody really knows yet how close, or if just showing as a possibility. I know the group hosting the races I'm in are.
#577
I don't think people are having a stroke over them. Not like the " rubber tires for 1/12" thread. Some there were actually threatened to quit the hobby if that happened.
#578
I'm still new enuff to F1 that if these new style tires were approved, it wouldn't be a big deal to me. But I do get that for those that have been running F1, the whole scale realism is part of the draw of the class.
It's hard to guess if these are just prototypes, that they are just trying to see what response they get. Just my view but I don't think so. Most of these brands seem really good at keeping things out of sight unless they want it seen.
#579
#580
Well, I bit the bullet and put the Montech front wing on the car and mounted a fresh PF Fifteen on it. I had to remove a little of the body just in front of the rear wheels to get the tip of the nose even with the front wing. The original body cut for the Associated wing was about 10mm too long. It's not painted at this point, but the fit is nice. Now I can pick or plan a livery for it. I'm leaning toward the FW14b Mansell car.
#581
Question - how do you guys enter a tight turn off a fast straight or faster previous corner? Or perhaps- how do you setup your braking?
I'm on high grip and I like to come into a corner fast brake hard then turn and accelerate simultaneously. However, I'm having trouble getting this car to brake as fast as I like as the rear ended starts to hop and likes to step out if I turn in too quick before it settles.
I've tried antilock and high and low braking strengths and end up going to regular brakes around 60% on a xr10 esc, but I keep wanting more braking power.
I know the cars are traction limited to an extent but wondering if any of you setup gurus have experienced this and what you did.
#582
My suggestions are:
1) adjust your braking technique just as you would driving technique.
2) ask Perry.
3) if you are Perry, go back to suggestion #1.
#583
Location: A step closer to where I need to be a step further from where I was
#584
Drag brake for me. Rely less on push brake which can unsettle the rear if you are not careful with your EPA and trigger control.
#585
less rear pod droop
