Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 05-24-2017, 06:10 PM
  #451
JustWill75's Avatar
So Bert, how is your F6 setup?
DARKSIDE likes this.
JustWill75 is offline
Old 05-25-2017, 04:06 AM
  #452
RC-ProSpeed's Avatar
Probably already been asked, but any feedback as forward servo setup?
Benefits of that setup compare to standard servo setup?
Thank you,
G
RC-ProSpeed is offline
Old 05-25-2017, 05:10 AM
  #453
celt's Avatar
Default F6 / X1
Just finished building the roller...
The F6 is every bit the kit that the X1 is - own both the X1 2016 and X1 2017. I diverged from the kit build by floating the entire servo and steering bellcrank. Post a pic or two soon...
Nice build experience without a single issue.
DARKSIDE and liljohn1064 like this.
celt is offline
Old 05-25-2017, 06:12 AM
  #454
cmb
So raced mine for the first time and had some fun. My only problem now is the front wing is now bent down on one side.
cmb is offline
Old 05-25-2017, 06:24 AM
  #455
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Dip it in boiling water, gently twist it straight and let it cool. Do not cool the wing in cold water. Repeat until your wing sits flat again. This is problem with most F1 wings.
liljohn1064 is offline
Old 05-25-2017, 06:28 AM
  #456
cmb
Thank you I will try that.
cmb is offline
Old 05-25-2017, 07:06 AM
  #457
celt's Avatar
Default few pics...
A few other small mods / adjustments.
Got rid of that pesky nut and ballstud on the outside damper tubes. Used an identical shock eyelet (31700) and pivot ball (4637) that's used throughout the rest of the kit. Nice and clean.
Also used a standard 3x8mm button head in lieu of the 8mm setscrew for the tweak springs. Provides a vertical and stable platform for the spring thumbscrews. Use a little Tamiya anti-wear grease and they won't move without the help of your thumb.
A few other "ideas" coming...
Attached Thumbnails Team Associated F1-f6_00.jpg   Team Associated F1-f6_01.jpg   Team Associated F1-f6_02.jpg   Team Associated F1-f6_03.jpg
liljohn1064 and NutDriver like this.
celt is offline
Old 05-25-2017, 07:10 AM
  #458
Trader Rating: 38 (100%+)
Unless you use the Tamiya f104-j wing. Never bends, raced mine for over 2 years before I replaced it because it finally got a crack in the wing.
liljohn1064 likes this.
chensleyrc1 is offline
Old 05-25-2017, 07:26 AM
  #459
Those Tamiya wings are hard to twist. The best in the hobby for sure.
Old 05-25-2017, 07:38 AM
  #460
Trader Rating: 65 (100%+)
I wonder if the 104 wing will bolt up to the F6?
chensleyrc1 likes this.
Antimullet is offline
Old 05-25-2017, 07:51 AM
  #461
Yep, best wing I've used so far for a lot of reasons:
- super light
- very durable
- sits higher so it never rubs the carpet or gets stuck under boards
- narrow - doesn't stick out too far and interfere with tight corner entry
- cheap
- looks good with narrow rear wings
DavidNERODease is offline
Old 05-25-2017, 09:13 AM
  #462
That wing is hard to find, but CRC Has them in stock in limited quantities!
Calandra Racing Concepts Inc.
dumper
scirocco14 likes this.
dumper is offline
Old 05-25-2017, 09:25 AM
  #463
Trader Rating: 93 (100%+)
Anyone have problems with too much on throttle steering? any input on the throttle while turning has me spun out facing oncoming traffic
3 new f6 cars racing at my local, all having the same problem. On a med traction asphalt track
Markus is offline
Old 05-25-2017, 10:00 AM
  #464
- super light
- very durable
- cheap
Yep and easy to find:
https://www.tqrcracing.com/shop/prod...w.asp?p_id=822
Old 05-25-2017, 10:36 AM
  #465
scirocco14's Avatar
What motors?
Mark
scirocco14 is offline
