Team Associated F1 >
Team Associated F1
Like Tree331Likes
Team Associated F1
Old 05-25-2017, 10:39 AM
  #466
Trader Rating: 93 (100%+)
Originally Posted by scirocco14
What motors?
Mark
21.5 Team powers v2 motors. I know super torque, but we're pushing the envelop
Markus is offline
Old 05-25-2017, 10:58 AM
  #467
Trader Rating: 50 (98%+)
Markus what tires are you running?
micrors4guy is offline
Old 05-25-2017, 12:07 PM
  #468
scirocco14's Avatar
I find on our asphalt track, I can't run 100% throttle EPA w/ a 21.5 motor. 25.5 motors, yes. But with the 21.5's (old NOVAKs and those are nowhere near as powerful as yours), I usually run around 80-85% throttle with some throttle exponential thrown in to calm the throttle curve down.
You can also experiment with throttle servo speed, I turn mine down to 90-95% to slow down the throttle. Sort of like traction control.
Hope this helps,
Mark
scirocco14 is offline
Old 05-25-2017, 12:17 PM
  #469
the normal pit/tcs/crc tires.
running radio curves already and seems like slipping the diff makes the car inconsistent.
Markus is offline
Old 05-25-2017, 12:36 PM
  #470
celt's Avatar
Originally Posted by chensleyrc1
One can argue the merit of aesthetics, but I defy you to break this wing.
Montech makes it for Xray I believe...
https://www.amainhobbies.com/xray-x1...371202/p478523
celt is offline
Old 05-25-2017, 12:40 PM
  #471
celt's Avatar
Anyone have problems with too much on throttle steering? any input on the throttle while turning has me spun out facing oncoming traffic
3 new f6 cars racing at my local, all having the same problem. On a med traction asphalt track
Markus...
Diff really tight? How much rear pod droop?
celt is offline
Old 05-25-2017, 12:45 PM
  #472
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The Tamiya J wing, which I believe is the same wing that Montech duplicated. These are the original F104 Pro front wing, not the F60. I have one of each at home in my spares.
liljohn1064 is offline
Old 05-25-2017, 12:46 PM
  #473
Diff really tight?
no quite the opposite. very loose slightly slipping. maybe that's the cause?
Markus is offline
Old 05-25-2017, 01:16 PM
  #474
celt's Avatar
Not thinking so, it would be the opposite...
Happens when you go hard into a corner and it oversteers?
celt is offline
Old 05-25-2017, 01:41 PM
  #475
only over steers when applying any throttle from mid to exit.
Markus is offline
Old 05-25-2017, 02:03 PM
  #476
celt's Avatar
What about rear pod droop?
I know the kit setup has about 3-4mm, waaaay too much for my liking.
That can load up the front end and cause oversteer for sure.
Antimullet likes this.
celt is offline
Old 05-25-2017, 02:15 PM
  #477
celt's Avatar
Default mystery chassis holes?
Has Bob commented on the purpose for the series of holes on the East and West side of the main chassis?
I'm hoping AE releases a nice set of weights that could be mounted there .
celt is offline
Old 05-25-2017, 02:29 PM
  #478
Trader Rating: 65 (100%+)
That is way too much droop imo. I'd try to take droop to about 1-1.5mm rear and 2.0mm front just to see if that helps with weight transfer to the rear.
liljohn1064 likes this.
Antimullet is offline
Old 05-26-2017, 05:21 AM
  #479
Billy Kelly's Avatar
Tomorrow will be second race. Weather is looking better. Simple goals for tomorrow
1. Finish all 4 races. Minor issue caused me to only run 2 of 4 first race.
2. Improve average lap time. 18.0 was baseline.
Billy Kelly is offline
Old 05-26-2017, 08:50 AM
  #480
I went down to 1mm and my on power/off power steering now has a nice balance too it for my driving style. I can now correct overall front grip just with tire sauce tricks: More, less and soak time.
