Tamiya TA07 pro
#916
#54031
4 degrees
carbon reinforced
#51293 is the standard glass fiber reinforced nylon version.
4 degrees
carbon reinforced
#917
I usually go through one every other race. Tonight was just not my night. Didn't even make it to mains.
#918
Thanks, this answers part of my question. But which is the version you want for the most durability on a carpet track with hard barriers? I thought I had heard the carbon parts (54031) were the very fragile parts that broke easily. Are the standard soft parts (51293) better for durability, or do I have that backwards? Thanks!
#919
#920
#921
#922
I had the same problem when running my car. I ordered the aluminum 4 degree C-hubs and as far as the steering blocks, switched those over to the Xray ones. They measure up almost perfectly with the Tamiya ones and I know they are durable (own three Xray cars). You could see if the Xray C-hubs work as well (just a thought).
#923
I had issues with the 418 carbon hubs back when I got my EVO6's in fall of 2015. Went with the TA05 hubs as they were way more durable, but flexed more than I liked. Once Exotek released the aluminum hubs, I bought those and never looked back. I never had issues with any other suspension part on any of my Tamiya cars.
#924
Been running my TA-07 Pro as a USGT car at my local carpet track since the first of 2017. Just box stock without the sway bars, the car has been handling very well. I did go with the standard 48p spur/pinion over the oddball Tamiya pitch ones. Currently using the stock springs with 50wt oil. Using 20K in the front diff and 10K in the rear. The carpet track I am running uses the CRC black high-bite. The car has been catching the attention of my fellow racers as it is performing better than my Cyclone TC and Xray cars under my piloting skills. The stock plastic C-hubs and steering blocks seem a little week but I have made the transition to the Xray steering blocks with no issues. I have the Exotek aluminum C-hubs to switch out if the current ones break. Liking this car so much I just ordered another one (don't know if I will go 17.5 or Mod with this one).
#925
I plan on running this car outside on asphalt - what suspension blocks would you guys recommend?
#927
Nuremberg toy fair 2017
Tamiya SSBB carbon shock tower set (f&r): #54746
http://www.directupload.net/file/d/4...fdivir_jpg.htm
#928
