Tamiya TA07 pro
#796
How did the TB04 with full option parts handle around the track compared to the TA07? Any feed back is appreciated
#800
Both had the same motor, battery and USGT tires. Differences were gearing (TA07 probably under geared) and body (TB-04R with a PFM-10; TA07 with NSX Concept-GT Lightweight w/ stock wing).
The TB-04R felt like it reacted more quickly than the TA07. The shaft drive, carbon shock towers, and reinforced plastics were probably the reason why.
The stock TA07 felt more stable, easier to drive, and more precise overall. Turn-in (rotation?) felt snappier and it held its lines through the corners better.
I ran a second a lap slower than Badboy during the race and finished 2nd. Gearing was 3.8 FDR I think.
#802
Helping a friend get ready for TCS. I own the TB04 already. Got the drivetrain very free. Just wondering what people think are the pros and cons between these two cars
#803
Trader Rating: 89 (100%+)
TA07
I have a fully optioned TA07 and I will be running it at one of the Carpet TCS races with the type C tires I have an NSX regular weight body I can run and an older lightweight Nismo Z. I have not run either body on the car or on carpet yet.
Any suggestions ?
#804
I've never used the type C tire. But I'd imagine that the normal set up would work. C-C front blocks XB- C or D rear. 6 & 5 droop. 50 weight front with white springs, 40 weight with blue springs. Or blue - blue springs. Should get you in the ball park
#806
Type C
I have everything set except the springs. Thx
#807
Max-San,
Shim the the outdrive to apply pressure on the O rings. They need a little bit of compression to seal. I doubt it will be a big deal to have a little more resistance if they're on the front as a heavy action diff. The 5mm shims worked best sandwiched between the diff housing and the O ring. If you place against bevel gear and O ring, it will wear a groove in them fast and start leaking again.
#808
Can anybody recommend a size spur and pinion for a reedy 21.5?
#810
TA07 will have better high speed drive train efficiency than TB04. Both handles very well for me with tuning but how the power delivery feel is very different. TB04 have high speed efficiency issues when you start to max out the rpm of a 17.5 on the straight. TB04 is a solid choice for smaller indoor carpet track as right now it does have carbon reinforced chassis option. TA07 is a solid choice for Large outdoor track with higher speeds. But for me I feel TA07 has less compromises and will have stiffer chassis parts in the future to make it better for higher traction.
