Tamiya TA07 pro
#496
Trader Rating: 89 (100%+)
#497
TA07 is a very heavy car, to compansate the heavy weight i will update the car with lightweight parts.
Alu screws and diff outdrives etc will be added
#499
I initially used tape to mount the battery pack to save weight but switched to the battery holder which is really fast and easy to use - great on hectic race nights. I think it also has less effect on chassis flex than using tape - especially if you leave the mounting screws loose.
#500
tam54690 spool, tam54544 lightened spool cups.
tam51565/51536 alum outdrives gear diff and blades that fit.
tam54077 alum swing shafts for front if you dont run DCJ drives but mainly for the rear if you do.
#502
Had my first shake down today and what a blast to drive, the car carries a lot of corner speed.
I was 0.6seconds faster then with my Spec-R S2 and only 0.3seconds slower then other high end cars that also run a 10.5T motor (FDR 5.4) while i was just running a 17.5T motor (FDR 5.3).
When i get the weight down to a normal competitive level, clean those bearings and do some more setup work i think i could easily go as fast as the other guys if not faster.
All in all it was a very nice start and the car has a lot of potential.
Now off to bed
Now off to bed
#503
For those who are seeking the lowest weight for their TA07, there is a low profile 5000mAh Li-Po battery from Arrowmax and the weight is just 249gr.
For those who think that's still to heavy they also have a low profile 4000mAh Li-Po battery available with a very low weight of 226gr.
#509
#510
http://www.redrc.net/2016/09/active-...s/#more-119516
New option parts from Active hobby
