Tamiya TA07 pro
#1981
I was running a 96\54 for a 3.29 with the 20t pulley when I was running the 18 tooth pulley I was running a 88/55 for a 3.28...... I was trying to keep my ratio close to the top dog at the track but what I noticed was my motor temps were higher with the 18 tooth and I lost the ability to pull mid-corner on the competition with the 20 tooth but overall lap times were faster what do you think you seem to be well-versed in this thanks...
btw I had to shave 1 mm off the forward (part # a15 )motor plate mount to get the pinion to clear.
#1983
#1985
#1987
Original weight with plastic housing and aluminium pulley. Oil: 1.4g, using big shim set, red o-ring, aluminium axles, plastic gears and ball bearings instead of bushings. Unfortunately i have no full plastic diff to compare...
The new aluminium diff housing...
The aluminium diff housing holds more oil. Finally i put 1.8g in it...
Work of art...
Weight of full aluminium diff...
Now the left and right belt guides have same height...
Laser markings...
