TT-01 Forum
#1351
BUT you don't need the upper deck in order to have the BB steering from the E. We've found the drivetrain is a little more free with the standard non-E parts. Some of us in Senior Spec run the E bulkheads and shock stays, but use the regular motor mount and gear cap in the back without the upper deck/stiffener. Just stack a pair of 8X5mm bushings on top of the steering links and use a cap screw to hold everything down. Awesome steering feel, easier to get the motor in and out, and the drivetrain just spins forever...
#1353
HI,
just got myself a TT-01 (mobile1 lexus) and the first thing I did was ditch the stock RX/TX and use my DX3R with a sr3100, now my problem is that reverse is kind of hit and miss, some times it works and some times the motor wants to go, but seems to get stuck...?
Any help would be appreciated.
Cheers
Cheers
#1354
hey does any 1 know if this 3 racing spur gear adaptor for the tb03 work for the tt01?
http://cgi.ebay.com/3Racing-TB03-14-...1%7C240%3A1318
#1355
If you go back a few pages I posted pictures of a spur gear adapter that I was able to make. The one I made works very well and not hard to make.
If you have questions you can pm me.
#1357
Can you confirm this? I think the bearings on the input cups are the same as those at the axles which are 5mm inner diameter, not 6mm.
#1358
After looking at it more in depth the tb03 spur gear adapter or even the EVO IV one might work. The TB02 was 6mm and the EVO IV and TB03 are 5mm. with some shimming it might work. I might try to get one to experiment with. I do know the one I made works great, but it takes some tinkering with the spur gear to make it fit.
#1359
aight thanks for confirming it didnt work , didnt wana waste my money . yea saw ur adapter you made a while back and looks pretty easy , was just thinking id try a already made 1 first but i think ill just follow your guide and save a lil money and have sum fun making it . what are the maximum size pinions and spurs and what combos have you tried ?
#1360
hey guys im still learning rc and i was just wondering what would happen if i put a ball diff in the rear of my car and i rallyed offroad . would it cause it to slide ? i was also thinking about getting the 3 racing solid diff which is like a locked diff , what would this make the car do if i was rallying offraod?
thanks for help
thanks for help
#1361
I actually think I am going to try the 3 racing spur gear adapter. i did not realize the the TB03 was that much different than the TB02. The dimensions of the adapter might be alright but it still might be too thick. It might be worth the $10 to try and modifiy it to fit.
As for the gear combinations for 64 pitch gears for the TT-01 here you go
I also figured out the 64 pitch gear combos for the A, B, C, & D motor mount positions.
A 121 total teeth
B 123 total teeth
C 125 total teeth
D 127 total teeth
That is the total teeth needed in any spur and pinion combination. You do have to cut a slit in the motor mount to be able to get an hex wrench in there to be able to tighten the pinion so the pinion meshes properly with the spur.
Good luck, it really is not too hard to make.
#1362
hey man thanks for the info on the adapter and the combos that work . i definetly gotta try making 1 soon , i live in malaysia so i try not to order to much . but that adapter looks like a weekend project , thanks for the tut u wrote aswell
#1363
hey guys im following a tutorial ive seen before on converting the tt01 to a buggy for offroad but it recommends that you change up the gearing because of the big buggy tyres. im going to make my own spur gear adaptor and i was just wondering what spurs and pinions should i use? i was thinking like a 67 spur and 18 or 19 pinion , but also what pitch of gears should i use? 48 or 64? and if any 1 has gearing suggestions please post them to
thanks
thanks
#1364
Hello all,anyone running a 17.5 an a 55t/25t setup ?
