Like Tree54Likes
TT-01 Forum
Old 09-26-2014, 10:20 AM
  #2401
longuylander's Avatar
It's almost 1500g. Using a VW Beetle body done up to look like Herbie doesn't help weight or aerodynamics either.
longuylander is offline
Old 09-26-2014, 10:36 AM
  #2402
Ah, OK. I tried white springs in the front, but the dampers would stay fully extended because the low car weight. My car will hopefully be even lighter soon with a light weight body and a thinner paint job than my usual "let's just empty a can on this shell to get it done quickly" technique.
Hugo
HugoW is offline
Old 09-26-2014, 02:37 PM
  #2403
I'm quite surprised... I dropped a Speed Passion v3 17.5T in with a Reventon R ESC in blinky mode, and was able to clock 28mph. Now if I can only tame that on power oversteer...
Old 09-26-2014, 11:42 PM
  #2404
Is it a sensored brushless? If not, there is your power delivery problem. I drove a 13.5t sensorless, plenty of power but too much punch. The brushed Cup Machine is easier to handle because power delivery is more smooth.
Hugo
HugoW is offline
Old 09-26-2014, 11:45 PM
  #2405
Oh, and did you free up your bearings and gears?
+ YouTube Video
http://www.youtube.com/watch?v=gCinjfeACRA
Hugo
HugoW is offline
Old 09-27-2014, 03:56 AM
  #2406
It's sensored, the car rolls freely, and I'm surprised it's that fast! With an FDR of 5.11 running a 17.5, I didn't think it'd reach such a speed. I tried a 13.5 in the car; it would get up to 35mph before the stock kit tires and poor aerodynamics of the Beetle couldn't handle the speed and the car would spin out. Guess I'll lower the gear ratio and enjoy the car for what it is, and leave the high performance to my other cars.
Old 09-28-2014, 11:32 AM
  #2407
machgo5go's Avatar
Default YR Aluminum Front Upper Arm
Anyone tried out this option to get camber?
machgo5go is offline
Old 10-03-2014, 03:38 AM
  #2408
machgo5go's Avatar
No dips that anyone had bought this set up in review?
Old 10-03-2014, 05:14 AM
  #2409
I have the plastic Tamiya ones, but for racing the stock non adjustables do well. These to me are more bling than function.
Cheers,
Hugo
HugoW is offline
Old 10-08-2014, 10:44 PM
  #2410
Thanks HugoW, cleaned my bearings and I could feel and see a difference.
Question, will the TRF Short Works dampers work on the TT-01? If so, what will the ride height be and will there be enough travel on the dampers
SRJRacing is offline
Old 10-09-2014, 01:45 AM
  #2411
We had/have a TT-01 class here that only allows Tamiya upgrades. All of the really fast guys are running the TRF short (M series) shocks. It's really the only way to get down to 5mm ride height.
.crispy is offline
Old 10-21-2014, 06:04 AM
  #2412
Hi guys,
I'd like to fit the better axles to my racer, the 53792:
But I use the wide wheel adapters, so these axles are too short. There of course is an easy solution, but I cannot find it...
Cheers,
Hugo
HugoW is offline
  #2413
Hi guys,
Cheers,
Hugo
HugoW is offline
Old 10-21-2014, 06:17 AM
  #2414
Is there a number on those? They sell them in all lengths. 48mm, 50mm, 52mm.
I get them from TQ RC.
.crispy is offline
Old 10-21-2014, 06:29 AM
  #2415
The number is there, 53792. They are 48mm as per the TT standard, but I want the axles sticking through the wheels to be long enough so I can place the wider wheel adapters, the little hex pieces locking axle rotation to the wheel.
Cheers,
Hugo
HugoW is offline
