TT-01 Forum
#2116
MD, I am basing my question on how TeamThibault set up the conversion as seen in his previous post that I quoted. The question was directed at him and not you. Your input, although not asked for, is appreciated but not valued. Thank you.
TeamThibault, do you have/know of anywhere to lessen my time looking for a tutorial on how to do the conversion you have set up? This would be very much appreciated.
#2117
dzinehaus start reading pages 138 and up
i just got my kit last night and hope to have it build by tomorrow night
then i will race it sunday to see how it works with the modz
#2118
Cool thanks TeamThibault! Will do.
I am also working on a mod for a tamiya 1/32 mini 4wd to be static to r/c.
Hope to post pics once i get all the parts in. Im thinking micro esc/rx/servo/shocks knuckles etc from kyosho mini-z.
#2119
I built some of the 58516 kit this monday
SO to night I took my chassis to a friend (cheaplikePhill)
Phill is a machinist and is a great guy
he took the ff-03 gear adapter and DID HIS THING....
after installing it the car he notice it rub a little and pulled it out and
took some more off on shaft end
now it runs like a dream cant wait for the weeked
#2121
Yup I have tamiya bearings and aluminum. Drive shaft in it I tryed the 46 pinion but I could not get it to mess. So I used a 50 tooth pinion and 75 spur. And that seems to work..what is my fdr?
With out a body but with electronics and battery it came in @ 1340grams race rdy
#2122
#2123
I have a question .. my tt01e is complete stock and when I am on a carpet track if I get a good speed when I turn I roll like a mofo....
how can I fix this? softer springs? anything else.. I am running silver and black cans so not alot of speed but still I cant take a corner fast without rolling over...also any other setup tips?
thanks
thanks
#2124
so I had some binding action going on... made the the esc/motor thermal ...so back to basics
rescue I did find a write up on urc friendly forums (what gearing are you using?)
#2126
thanks
thanks
If you are rolling on corner entry first change the front springs / oil only. If its on the apex that it rolls try stiffening front and rear, exit on power the look at stiffening the rear.
#2127
You'll want the Tamiya spur gear adapter designed for the FF-03 car, Tamiya part #54234. The mod is super simple and all you need to do is drill it out to 5mm so that it slips onto the rear stub drive shaft.
I have mine oriented so that the spur gear attaches from the rear. I did need to file the end of the adapter slightly so that the holes in the shaft and adapter aligned.
I ran a 75T spur / 46T pinion combination giving an FDR of 4.24 on silver can motor. The day was extremely hot but my motor came off the track at 120 degrees.
Sh*t I just noticed TeamThibault running 70/55. Did that not explode?
#2129
I finally got in my chassis, but I had ended up leaving my tools at work:/ So I am just going to get a set for home. I also need a new spur gear and am extremely low on cash ($1.76 to my name) so if anyone can help me out and tell me where I can get one DIRT cheap, that would be greatly appreciated!
#2130
TAbrown, Ill send you a either a 61 or 58t tt01 spur by eagle racing. pm me your address.
