NEW XRAY T2
#5598
Hoping that I can get some opinions on the BMI chassis for the T2. I am looking to upgrade my car for this winters carpet season and I was wondering what I would gain/lose by switching to the BMI version.
Thanks,
Mark
Thanks,
Mark
#5599
Team EAM
Thanks,
Mark
Thanks,
Mark
Gains: Nice 3mm thick chassis, top deck and shock towers. Beveled edges on the battery slots that are perfect. Super stiff chassis that also lower's all the roll center's at the point of contact for the rest of the chassis. By the car being stiffer it will also free up in the corners and carry more corner speed while not tweaking on impacts.
Losses: Battery strap doesnt match the C/F of BMI.
EA
#5600
Thanks EA!!
Sounds exactly like what I'm looking for. One more quick question for you. Are there any major setup changes I should be aware of when I switch?
Mark
Mark
#5601
Location: Curacao, Netherlands Antilles, Dutch Caribbean
President
I nominate EA for president.
While we're at it though: BMI or original Multi flex for asphalt?
#5602
Team EAM
Thanks EA!!
Mark
Mark
No you shouldnt have to change anything setup wise. I havent noticed anything different at least.
EA
#5603
Team EAM
BMI also has an Asphalt kit that is very good. I didnt get to run it but I think some of the Team guys may have ran the top deck at the Nats. There are some differences but I am not 100% sure what they are as I havent seen one in person. I'll see if I can get Jason to answer better for you.
EA
#5604
I can help ya here EA...
The BMI asphalt chassis is 2.25mm graphite as opposed to the 2.5mm chassis that is stock to the T2.
The BMI kit doesn't have the cut out slots for multiflex. Being 2.25mm is just the right amount of flex without having to adjust it with screws. The top decks are made out of 2.25mm graphite as well with no wings for corner posts.
The kit works great on asphalt. I used it at the Express race in NJ - TQed and Won both stock and 19T and my TQ in 19T was faster than the Mod touring TQ!
You can ask Alex Lopez about that.
#5605
How much difference is there in lap times with the stock T2 chassis vs. the BMI Carpet chassis?
#5608
for the most part,i changed the way the car is braced and also the roll center and CG.i pocket under the bulkheads,motor mount standoffs down to 2mm.this seems to keep the car more flat going through corners and increase corner speed.the chassis allows you to brace the car wide or narrow for a different feel and increased rigidity.the kit makes the car extremely stiff and easy to assemble due to the countersunk mounting holes on the top decks and shock towers.no guess work or messing around trying to get it to go together straight.
#5609
will the Serpent RCC Shocks fit the T-2 not that i dont like the plastic shock bodies but those aluminum shocks are nice to have and i cant find any X-Ray T-2 aluminum shock bodies
#5610
My son just ran a warm up race for Vegas, with Jason T2 carpet chassis. (FAST) would not run anything else.All AAAAs Jason,
