NEW XRAY T2
#5401
Here comes the pics of the delrin/steel spool, the final version of the aluminium/delrin spool and the installation in the car with Tamiya bones.
#5404
Very nice unit. To bad some companies think that only the design they start with is the best. This set up is much nicer than the multi diff and the dumb blade system.
#5406
If some of you might be interested by buying one, PM me.
I think only few unit can be done at the same time by my friend because it take him some time of work, so it can take a litlle time.
with the stock XRay diff you can't use tamiya bones because you need to use blades. Maybe with the platic ones of the T2R it will be possible but i don't know.
With latest spool, we use 46mm bones
Originally Posted by lbckevin
What size tamiya bones fit in the stock diff in the front and rear ?
#5408
exact, but I don't know if tamiya blades fit the xray diff outdrives, I should have a look!!
#5409
Now that's what I'm talking about!
Stong and solid. I love my Xray, but if they keep jacking up part prices, I'll find a cheaper hobby. The price on the bones and diffs are outragous. The diffs don't even come with carbide diff/trust balls. When's a aftermarket company going to reap from Xray's greed? I say loose the blades and make a wheel bearing hub spacer. Please make some changes Xray! Just my two cents.
#5410
#5411
The kit comes with them...but.
Originally Posted by Nexus Racing
Per the manual, they do come with carbide diff and thrust balls...930120 and 930138.
#5412
When's Xray going to offer diff halfs separate? I just ruined another and I out for a month. I can't take it anymore! Please tell me that Xray will offer a plastic diffs at a much lower cost. I want to be able to buy what I need and not be forced to spend $60 every time I need one diff half.
Darkside Motorsports
"WE ARE WHAT'S NEXT."
#5415
With the spool I use the 46 mm ones but with the diff you should use the 42mm because XRay one's are 43mm long.
Tamiya blade seems to be 3mm so it might work!!
