NEW XRAY T2
Old 08-01-2006, 05:44 AM
  #5356
XrayFK's Avatar
I heard 116T is the biggest spur that fits for 64 pitch, what about for 48 pitch? Thanks.
XrayFK is offline
Old 08-01-2006, 06:02 AM
  #5357
sukh's Avatar
i run a 120 64p spur, it fits!
sukh is offline
Old 08-01-2006, 06:17 AM
  #5358
87
hugovdb is offline
Old 08-01-2006, 04:41 PM
  #5359
JCB
JCB's Avatar
Originally Posted by Nova F1 Racer
OK, this kit came with the diff pre-assembled.. They feel about where I would have set them... I really don't need to take them apart now do I???
A pdub bumper?
I threw on the Parma bumper this weekend on my T2. Fits great and very strong...
JCB is offline
Old 08-01-2006, 07:17 PM
  #5360
Nova F1 Racer's Avatar
OK... I'm befuddled.... I put a standard pinion on a moster stock motor and unless I put it on backwards I can not get it to align it with the spur gear.
Do you put spacers between the motor and the bulkhead?
I rechecked the spur gear assembly and everything is correct...
The drivetrain is free..... What am I missing????
THX
Nova F1 Racer is offline
Old 08-01-2006, 07:25 PM
  #5361
XrayFK's Avatar
THX
What's wrong with putting it on backwards? Some gears won't fit otherwise I think.
XrayFK is offline
Old 08-01-2006, 07:43 PM
  #5362
PlainOleDave's Avatar
Trader Rating: 14 (100%+)
Who is to say what's Forward or backward? If it fits and it run true then it must be right.
PlainOleDave is offline
Old 08-01-2006, 07:57 PM
  #5363
I guess that I'll install it like the pinion is on the Tamiya TL01 with the set screw near the end of the shaft.....
Old 08-01-2006, 08:15 PM
  #5364
Trader Rating: 208 (100%+)
THX
I did not know there was a backwards way to a pinion gear.
I run robinson gears and the set screw is on the right of the car. No problems with this.
dodgeguy is offline
Old 08-02-2006, 03:32 AM
  #5365
Kyle Wilson's Avatar
Trader Rating: 17 (100%+)
YES!
Kyle Wilson is offline
Old 08-02-2006, 07:01 AM
  #5366
teamgp's Avatar
Some 120t 64p and 90t 48p spurs will fit without sticking out of the bottom. However, some brands will stick out the bottom of the chassis about .1 to .2 millimeters.
In the interest of safety and possible track rules, we recommend a maximum size of 118t 64p and 87t 48p for the T2. Keep in mind that we used a 116t 64p spur for the foam tire gearing chart included in the kit.
teamgp is offline
Old 08-02-2006, 07:03 AM
  #5367
teamgp's Avatar
Thats the standard "right" way for the T2.
teamgp is offline
Old 08-02-2006, 10:08 AM
  #5368
Well, it looks kinda funky but it fits!!!
Now to put in the ESC and see if it fits nicely!!!
Old 08-02-2006, 02:43 PM
  #5369
Just a few points:
The pinion also mounts "backwards" on My RC10T.
Some may not realize but when others say some spurs will fit and some will not, They are refering to the mounting holes being different and some are metric teeth and some are SAE (Standard/old fashioned).
The metric Spurs also need to be run only with metric Pinions as they do not mesh correctly with SAE spur gears.
Old 08-03-2006, 01:51 AM
  #5370
hey everyone i just got a T2 and was wondering if anyone had a good setup i could try for foam and rubber and foam im using the bmi chassis .
mush104 is offline
