NEW XRAY T2
#4831
Originally Posted by Midnight
Does anyone know what spur gear to run on the T2? On the O5 I was running the pse 116. I wasnt for sure if the diff in the gearing was going to make a big deal.
#4833
#4836
I was reading last night that there was a problem with the rear hub carrier. Is that fixed yet.
#4837
I think he is talking about the mold issue with the rear toe. The fix your talking about is a problem with crashing lol.
A very good fix though. I will put grubs in my hubs tongiht.
#4838
Almost all cars have a slight variation. I have never worried about it because all you need to do to fix it is shim left and right a little different. Although I swear I can feel bigtime the difference between ALL inboard toe in and ALL outboard toe in, but I dont think I can feel the difference of having a 0.075 shim on the left and a 0.04 shim on the right to achieve even total toe in!!
#4841
Originally Posted by Patriiick
You should see a doctor for that
#4842
#4843
Well-I got to thank everyone for the set-up tips. I ran full mod last night and car was awesome from the first battery pack. I had a bad endbell possibly though (sticky brush hood) and roasted two brand new DC 7x1 and 8x1 arms and dumped when a cell decided to give up the ghost on me after charging (PPPPSSSSSSSS...). I got nu luck in club races-EVER!!
I also ran the same-set up first in 19t and it was really good there too. I went mid front and flat pins and high rear roll as many suggested. Easy to drive and good corner speed-just rolled through the apex.
Ray
Ray
#4844
On carpet, are the majority of you running the standard chassis and top-plate or are you using the BMI stuff?
#4845
Ray
Ray
