Tamiya Direct Drive Touring Car
#1036
I'm not saying you should buy your parts here, but they do have some things that have been asked for, like:
64p Spurs (96T 98T 100T)
Diffusers (2 types)
Take a look
RC Mart's F103GT parts selection
Diffusers (2 types)
Take a look
#1037
Diffusers (2 types)
Take a look
Diffusers (2 types)
Take a look
#1039
I used a 4.7 (104/22) ratio @ SIR with the kit type silver can and it felt very good. I would think on a longer track like Tamiya you would need to gear up to 4.5 or possibly taller.
Mark
Mark
#1041
If I had to guess i would say its 50x90, but the longest straight was only about 75ft.
Mark
Mark
#1042
Originally Posted by RCGaryK
What gear ratios are you guys running with Mabuchi's? I think I remember what I used to run with the F1 tires, just verifying.
At Trackside we were running 93/24 or round about that, give or take a tooth or two. Really dependent on how your motors run.
#1043
Originally Posted by BP SHADOW
Gary,
#1044
For Sale - I have just listed a NIB F103GT Chassis Kit, Courage Body Set and F103GT Hop-ups, Great prices, see the link below:
http://www.rctech.net/forum/showthread.php?t=158485
#1045
you got PM..
#1046
How is everyone mounting there steering servo?
Also, for you guys in So-cal does anyone know if Tamiya will allow the servo to be mounted flat on the chassis?
#1047
I keep breaking T-Bars. Any suggestions?
Is the 3 point suspension hop up any good?
#1048
Brad, do you remember what we geared for TA? I was figuring with the tire diameter difference that I could use the rollout to kinda get me in the ball park from the old F1 tires to the sedan ones, but not sure.
I cant remember for sure as I am very bad at keeping records of this kind of stuff, but I think I was gearing in the 27,8,9 range with the 93 spur. You guys always had a better handle on the F103's at TA than I did so you may have been completely different ( if I remember one of you guys were running a 100 spur at one point, but I cant be absolutely positive) Im trying to figure out if I will run GT2 or 103GT at the Nats this year.
#1049
#1050
The only time I have seen a broken T-plate is when the car was run over by a real car. Are you running indoors on carpet. Running in GT trim with a full body, the breakage should be next to none. If you are referring to the ball pivot rear suspension, for the F103GT, it doesnt work so good, but for an F103 F1 it is a good alternative to stock. For help with the T-plate issue we need more details.
First I broke the origional Tamiya T-bar, then ordered the graphite T bar. I broke it racing today and could not complete the race because my track doesn't stock tamiya.
I am using the Opel Astra body. I run outside on asphalt. The races are not clean, and lots of rubbing. Both times I broke the T bar was due to getting pushed into a wall. I was coming out of a corner and another racer took it hot. The back of my car was clipped and it hit the wall. The rear tires hit the wall hard and due to the design of the car it caused the T-plate to snap.
I was looking for a T-bar that is a bit more durable. Has anyone tried the T-bars from Kawada?
http://homepage.mac.com/alvin.yap/Ho...otoAlbum9.html
Kawada Part Number F0-316
The 3 point suspension is on the same page
Kawada Part Number F023
