Tamiya TB-Evolution III
#1006
FYI? umm i'm very confused as how to work all this out.
if i use use the stand 34t pinion and 90t spur
i'll get a final drive of around 7.3? good enought starting point?
please help i feel like a dummy.
#1007
evo 3 setup
If you're really set on using a Tamiya stock motor, then the RR is great. But If you go up agains X-Rays and stuff, I went the way of either the MVP and Revenge of the Monster. Great torque, and as much rpm as you can get for a stock motor. I used the stock gearing that came in the box. 96 spur, then played around w/ 30 to 38 pinion. it really depends on the layout of the track, wether it be high speed or technical. Tires, I'd go w/ Take-Off CS 27, or Sorex 32-r.. If you want to stay Tamiya, everyone at TCS runs B2 compounds. It sticks really well. 1500mah batts!? wow.. heheh.. that was back when I used to race my FF01 and TL01. lol. I didn't know they still used those. lol.. I wouldn't know about batts, I never use anything under 2400. usually 3300's
On race day, competition is fierce, people get hard, and racing gets intense. But nothing is better than a qiuck smile, which just changes the mood=).. heheh.. It's an intense sport.. but HAVE FUN!
#1008
final drive ratio(fdr) = spur/pinion x internal ratio.
as peter says , tb ev0's internal ratio is 2.6
meaning 90/34 x 2.6 = 6.88
which is close to 6.6 that i mentioned.
i belive this is the stock/box gearing that came with the kit.
u can easily change the gear's by buying other brands...but im not sure yet.
u can of cos try 6.88 and see how it goes on ur track.and change/adjust from there.
HOWEVER,to be competitive it's always wise to have a wide selection of ratios so u can change for fine tuning.i would say 6.88 is a little too short.my base is under 6.6.seomtimes i go for 5.8 just for speed but it's dangerous if ur not careful abt overheating ur motors.
dont be shy to ask more if ur confused..i was just like u sometime ago.
#1009
thanx Lee, i understand now, i'm gonna start out with the std 6.88, and go from there, i think they sell spurs at the track so i should be alright. i'll let ya know how i get on when i get my motor
thanks again your've been a big help
#1010
Peter Robinson,
can you please post the "smoking carpet setup"?
I`ve trouble with car on carpet with Sorex 32 tires.
#1011
Tech Racing Diff Gear Plate back in stock
The Tech-Racing one way gear plate (EV0001) is now back in stock at RainbowTen. I received my gear plate today along with some nice Tech-Racing grey al. body posts (EV0002) for the front bumper to replace the plastic posts which seem to bend and break.
Will try the plate this weekend and report back. It looks well made and comes with extra long screws to mount it onto the diff gear and one way. About US$3 each and if they do work will be the best "hop-up" for the Evo3 yet
I will also be spending some time shimming the spur gear holder to minimise slop in the drivetrain.
#1012
Here's that "smoking" carpet setup.
Also, working on an "owning" asphault setup at this time.
#1014
8th Yama Yama Cup
1-2-3 finish for Tamiya TB EVO3
Surikarn survived the frosty weather to finish an inspiring 2nd behind team mate Satoshi Maezumi, who has now won four times at this winter meetings. Masayuki Oyaizu completed the top three line up. The TRF Team managed to put three of their drivers in the A-Main and a total of 5 TB EVO3s in the A Main.
Surikarn and his Dad arrived in Japan on Thursday morning and headed straight to the Miwa Hobby track, accompanied by TRF Team members. Unfortunately, the day was ruined by the rain, forcing everyone to move and practiced at the indoor track instead of the event venue outdoor track. Surikarn seemed to adapt to the new track quickly and was the fastest man on the track. This was his first major event with his new ride, TB EVO3. While he admitted that he was still to find the best setup, he had already shown the superiority of this new chasis to the competitions back home in Thailand. All of TRF members now run the TB EVO3.
#1015
i wish i knew what the factory drivers are doing with there 1 way gear. plase keep us updated on the new one way rings and greas thanks
#1016
Originally posted by peter_robinson
yes, that has just come about, and i feel greatly honored to represent a team and a company that i have admired for so many years!
by the way, who is this?
peter
peter
The way I'm making money with my new job, I can smell the EVO III getting closer in the air guys *big grin*.
Btw, Mr. Robinson, what kind of ESC are you using with your EVO III? I have LRP Quantum Comp brand new in box that I've been saving for a special car but I'm afraid of using it ever since I blew two Quantum Sports in successions with different cars that I have in it. I might use the Keyence A1Z that I got on my EVO II or I might ended up getting one of those Msonic ESCs from hobbypeople. What is your suggestion?
#1017
I drive with the Icelandic LRP racing team, and I'm using the LRP Quantum Competition in my TB EvoIII. There shouldn't be any problems with any kind of Quantum. The only thing you have to watch out for is that you put a little tape on the edges where the battery touches your chassis. Also watch out that you don't have one wire plugged in and let the other one touch the chassis. This will couse the speedo to burn over!
I'm in no doubt that the LRP Quatnum Competition is one of the best speedos out there!
Go ahead and use it in your new car! You won't regred it!
Regrads,
Andri Orn [ICELAND]
LRP - Tamiya - Team Orion
#1018
Servo Saver
I just raced my TB Evolution III for the first time this weekend at a very strong indoor carpet race up here in Iceland. All of the Icelandic top drivers were there and I finished up 4th, wich is the first time for a long time that I'm not on podium!!
Anyway, I find the Servo Saver that comes with the TB Evolution III very crappy! What servo saver are you guys using??
Can you point out any good servo savers from somone else?
Thanks!
Andri Orn - Iceland
Thanks!
Andri Orn - Iceland
#1019
Carpet setup
Holmenkollen,
here is the setup that you have asked for.
FRONT
Shocks: Oil- 50wt
spring- associated gold
piston- 2 hole
one oring in the bladder
camber- 1.5 degree neg.
one 0.7 shim under front block for kick up
droop- 24.6mm (measured from the top of the axle)
arm spacing- normal
camber link- normal
Shock mount on tower- middle
shock mount on arm- outer
ride height- 5mm
REAR
Shocks: Oil- 40wt
piston- 2 hole
one red sponge in the bladder
camber- 2 deg. neg.
1.5mm shim under both front and rear hinge pin blocks
droop-24.5mm (measured from the top of the axle)
arm spacing- normal
camber link- normal
Shock mount on tower- all the way out
Shock mount on arm- outside
ride height- 5mm
MISC
motor- Trinty 19 turn (gearing 35/96)
Orion 10x1 (gearing 27/96)
battery- orion Gp 3300
this started as David Jun's setup from the Novak Touring Car Championships, but for carpet tracks here at home, the setup was not ideal, so this is what i have done to post record lap times at my home track.
peter
FRONT
Shocks: Oil- 50wt
piston- 2 hole
arm spacing- normal
camber link- normal
ride height- 5mm
REAR
Shocks: Oil- 40wt
piston- 2 hole
camber- 2 deg. neg.
arm spacing- normal
camber link- normal
ride height- 5mm
MISC
peter
#1020
nobody...just another Tamiya fan who have had too much time on his hand reading too many RC Car Action on his spare time. I followed your domination on TCS for the last years or so. It is nice to see that you can finally show the world what you are capable of with a Tamiya (read: skill).
peter
