Tamiya TB-Evolution III
#6481
Originally posted by marvi
thanks for the info ive also asked in our lhs and theyre having difficulty locating the tech racing shaft - so this explains it. oh well, i think ill just take my chances with the stock drivetrain components and hope that the gears dont strip too often i ran 2 battery packs a while ago and after a couple of crashes, the gears seem to be holding up.
#6482
if i get the new shaft, do i need to shim the gears? btw, do you have a part no. for the 2mm longer shaft? i was in our lhs this afternoon but they only have the original evo3 shaft.
#6485
work: thanks for the info the tamiya dealer in makati has no stock of the longer shafts, ill try my luck in megamall tomorrow. i ran the evo for the first time this afternoon, after a couple of battery packs, it seems to accelerate out of corners faster than my TA04, even with a 5.8 ratio (i ran my TA04 with a 6.0+ ratio)
i still have to set it up because it has a bit of understeer. plus, i still have to work out my gearing for 23T stock. ill see what it can really do this saturday hope it doesnt rain. thanks for the deal
http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
if i cant find one locally, ill get this one. i hope it arrives here within a month, my last tower order took almost 2 months before i got a notice from the paranaque post office
#6487
Could someone tell me how many teeth the diff pinion & diff gear have?
#6489
i think speedtech rc has the square aluminium gearboxes if thats what u want.
#6491
are the aluminium gearboxes worth the weight offset they have. or do the plastic ones cut it when the threads arent stripped??
#6492
stripper
dammit i keep stripping the front input gear, why is that? i have alreaddy went through like 5 input gear and 5 front one way bevel gear! would the lw shaft cure the problem?? is it longer? its the inside hole of the input gear that keeps getting stripped. any ideas????
#6493
Regional Moderator
Re: stripper
#6494
Pros
- drivetrain is much more free
- bearings are better supported
- no more stripped threads
- looks really cool
- no shimming necessary. Every Square gearbox is the same unlike the plastic gearbox.
- much stiffer chassis. I´m using the 2.5 mm chassis only and this is even stiffer than the 3mm chassis with the plastic gearboxes.
cons
- won´t help very much with the oneway gear problem
- a little expensive but really worth the money
- heavier. But you could remove the center brace with the screws and save a little weight again as the chassis is so stiff now so the brace isn´t needed any longer.
#6495
i think he means the keyed biy that goes on to the prop rounds off.
if it does you cant do anything to stop it.
its only happened a couple of times to me.
always on the front tho.
never had any probs with the back.
