Tamiya TB-Evolution III
#288
drive train efficiency
Just a couple things on the drive train.Since the bulkheads are plastic and can easily tweak,when mounting the sway bars,do not over tighten the mount into the bulkhead because this will also cause binding.Its the same as not over tightening the diff cover to the bulk head.Car builds really easy.I am happy.Great Job Tamiya once again.
#292
We will have the Evo3's in our shop for $300 as soon as Tamiya America gets them.
I couldn't justify paying for an early grey market import this time, so I can't wait! Too many cars already...
#293
Thanks for the battery slot help. I'll leave mine the way it is. I guess the diagram on step one is a little misleading because it illustrates the chamfered edge on one of the slots as a right angle. It'll be easier to remove material later on if needed.
Joven, I'll save you a seat but I won't have my Evo3 ready by then. I'm rebuilding the 414 and will be running that instead.
#295
Thanks Izzy
To all,
Did anyone try the difference of running the stock set-up, or running without the plastic center-brace?
Pizza
To all,
Pizza
#296
Originally posted by izzyracer
Madjack or anyone, will that help keep the Battery in place?
#298
First run
Okay-Here is the deal after my first run. Good news and bad!! First some info.
I ran a not so good stock motor, Jaco Foam tires on a fast 90 x 50" Ozite carpet track. Tarction was medium dues to it being cold in building and unused for a week.
I first ran my Losi XXXS and it sucked. Made it better then when i was happy with it I ran my TC3. Got that really good the decided to run some circles and set the EVO3 up just a bit. Well i ended up running two packs through it. First the:
bad news There were three major interferenace problems with the foam tires. You cannot run a rear sway bar. Tires lightly rub the top of the rear uprights. And last-major interference on the top of the ballstud on front C-hubs. I cut the top of the ballcup off, but ti still rubs. I must either cut some of the top of the steering upright off so ball sits lower or grind off the top of the ballstud. Bummer!!
good news The car felt exactly the same as my TC3-only smoother and less twitchy. The drivetrain had a lot of drag in it from being so new-but I think it will get better. When I would lift-car really slowed way down. that and that the front rims still ride on the ball-cups.
The car is manual-stock settings except for these changes.
Front
Shocks-60 wt. oil-no red thingy. Associated white spring.
4mm ride height. I dialed in just 2mm of uptravel.
Rear
Shocks-50 wt. oil. Stock yellow spring-but was going to change to Associated copper or purple. I know its the way to go!!! 2mm uptravel. Also A block in rear for 2 degrees toe in. No sway bar.
what I am going to change next
Try TRC foams as they have a bigger diameter rim.
drill new holes for the rear sway bar.
Move front camber link out one position (shorter).
Ttry a front diff-still running front one-way.
Overall i am very pleased that car right out of box was that easy to drive!! Also-I am amzed how easy it is to drive with the one-way. it doesnt feel any different to me than a diff. maybe because of the rims hitting!!!
Front
Rear
#299
R, I checked continuity on the chassis and found out that the top and bottom layers of the chassis are not conductive. It's the layers that are in between that are conductive. Use CA and CA it really good in the battery slots. Also make sure to shave down the edges for it can cut the battery shrink and might end up shorting it.
#300
Hey dan, If you still have problems with the tranny clicking i have a solution for it. Email if your interested in knowing.
