Team Associated TC7 & TC7.1 Touring Car
#1231
My car is already as light as your 1330gram tc7, but once I get the dynotech light axles, my car will be under 1320grams, and I will come down to 360v2 to race...
Redrc did confirm the new roar 1350g minimum weight... Double check that. You might be missing out ....
Until u show up to race night its all for crap my 4 year old could probably put u half a lap down with his m05 chassis stop typing on the tc7 thread about a dinasour car with more money in it than your broken 1.1 car and prove everyone wrong.
I have a saying
(Just shut and race) and prove them wrong
#1232
See you all at the track soon.... Cheers.....
#1235
The pictures are really cool
#1236
on the other hand both of my cars did very well today...setup was on point, and even set my best in USVTA with a hot lap of 11.3!!!!...my cars are basic setup from the build with aluminum AE chassis, and 0 deg in the front and -.5 deg in the rear. Traction is insane at Thunder, even after the Nationals a few weeks ago....My USGT car was very smooth and as a driver, it was enjoyable to control...loving these cars
also tested my Mod car for the 1st time and man oh man...what a difference...running Keven 7.1 setup, and car was pretty good...driver not so...plus new to mod/boosted and fried my motor...lol...but still good learning on the day
#1237
Question - I am running a 7.1 in USGT. Do the 17.5 chassis setup work well as a starting point or do you generally run different setups in USGT due to the tires? The USGT tires seem to lack steering. Thanks in advance!
#1238
My 17.5 and USGT setups are the same. .5 deg camber is usually the only thing different.
#1239
I haven't had a chance to troubleshoot it. But I have a 410r in my tc7 running 17.5 and in second qualifier the brakes went out. The blinky lite is blinking and it shows full throttle but the brake lite does not come on red.
Do you think the ESC just needs to be recalibrated or could I have blown the brake side of the ESC?
#1240
Set all your end points back to regular on your radio. Then re-calibrate your speed control. That would be the first thing a try. Think of it as you're doing a reboot. If that doesn't work then of course send it in for repair.
#1241
Yes try re-calibrating then see what happens.
#1243
Something fairly close to the kit setup is what I'm going to be there with for the az champs race this weekend, see you there. I'll be under the black ActivRC tent.
#1245
TC7.1
I am buying a TC7.1 to run on medium grip bumpy asfalt. What SETUP and HOPUPS should I put into this car?
thanks
thanks
