Awesomatix A800/A800R
#3601
I asked this question to a guy i race with w/ some solid feedback. But i want to see what you guys do to do 2 things on your A800s...
1. how do you remove your axles from your hubs succesfully w/o breaking shit? i'm wanting to clean my bearings
2. how do you remove the plastic pieces (dont remember the part number) on the AT21 w/o breaking them? I want to replace them w/ the AT21s to see how that runs
#3602
2 I would revise that you should replace the plastic cup due of wear and tear
changing over to AT21S will lower your roll center
#3603
I'm new to awesomatix hence the questions before i go to work, hence the questions i would like answers to
#3604
Use a flat object to press the axles out. I would also just buy new P03s, it is difficult to remove them without breaking them, and then they will be sloppier for the new balls.
#3605
so i can basically press it against my glass table and it pop out...but the plastic P03s I guess it is, i just need to pray that i have enough of those to replace. thanks
#3606
#3610
Max Mächler also posted his MMCX-A setup. Might give that a try for Sunday...
#3612
Thinking of switching out to long arms on my Us MMX what does the longer arms change as fas as overal setup of the car in regards to roll centres and such, and also can anyone explain what adding or subr]traction shims under the Ats 21’s does to the handling of the car. Thanks Ron
#3614
Watch all of Ryan Maker's videos which are on PetitRC.
#3615
I've got a local track with carpet that I'm thinking about starting to race again at. Which chassis you y'all recommend? the hard or the soft alloy spec car?
Jake
Jake
