Awesomatix A800/A800R
#3452
I'm assembling the mid motor conversion kit and I have a question about the AM77MM part as it's a bit different than what's shown in the instructions. The instructions shows the bottom of this part to be flat but mine is raised up on one side to allow a gap between the part and the chassis. When installing the one screw at the end of this part am I supposed to install a washer between AM77MM and the chassis?
#3453
Super Moderator
#3454
-a
#3455
There are two instruction MMC and MMC2
you should follow the MMC-2 instruction show no washer...
#3456
screw out for now and add it later to see if there's a difference in how the car feels.
I followed the instructions for MMCX-2. It doesn't show a washer but it does show to install a screw. Anyways I'm leaving this screw off for now. I'm looking forward to some track time with the mid motor conversion later this month. I'm hoping there will be an improvement over the A800a with the khaki chassis.
#3458
If your 2mm wrench has a long tip, is possible you connect into the head of the screw which hold the AT120 Pulley in position. At this case it feels like AT55M is tight, but it may isn't.
May check this tip at tightening of your AT55M spur nut.
#3460
R/C Tech Elite Member
a800x evo, a800xa evo and a800xah evo kits are available in stock for the first time since product launch now at Awesomatix USA
#3461
Super Moderator
#3465
