World GT-R Rules and Discussion >
Like Tree829Likes
Old 06-13-2018, 10:28 AM
  #1441
I believe that the wheel base limit for wgtr is 10 to 10.5". Even if a body might fit, the wheel base might be too long.
slotracer577 is offline
Old 06-13-2018, 11:27 AM
  #1442
YoDog's Avatar
Trader Rating: 28 (100%+)
Originally Posted by MC Hamilton
I purchased two sets of CRC pre-mounted tires in January. All eight tires have come unglued multiple times. The other guys I race with are not having the same issues. I reached out to CRC but didn't hear back. Maybe they changed something in their process? A different type of glue? Something. I plan to glue my own from here on out.
Hmm, Never had a problem with the pre-mounts. Maybe a bad batch that wasn't cleaned properly. Hit up Dumper in this thread, he may be able to respond to this.
YoDog is offline
Old 06-13-2018, 11:44 AM
  #1443
liljohn1064's Avatar
Trader Rating: 17 (100%+)
WGT and WGTR bodies are 255mm +/- a couple mill or so. F1 is 275mm. You'd really have to hog out the wheel wells to make up 20mm. F103s will work though. They are shorter and wider than current F1 cars.
liljohn1064 is offline
Old 06-13-2018, 01:50 PM
  #1444
Trader Rating: 22 (100%+)
Look like theres a lot of complications when converting an F1 for WGTR, and the jconcept conversion cost alot for couple of conversion parts plus I dont have the AE chassis. What are good chassis that are out there? Looks like team assosiated discontinued theirs. Is the Roche P10w legit for this class, might as well stick with the rules if im going to build one for this class. https://www.activrc.com/collections/...nt=27788805065
GhenzZ is offline
Old 06-13-2018, 02:04 PM
  #1445
Khador12's Avatar
Hanulec ran the Roche Evo 10 at the MHIC. The car was a rocket! This is the new updated version for 2018.
Rapide P10 Evo 1/10 200mm Competition Pan Car Kit
Khador12 is offline
Old 06-13-2018, 02:39 PM
  #1446
I'm liking my X10 so far. The only purpose built rubber cars, to my knowledge, are the speed merchant and CRC. I did hear that Roche is supposed to be coming out with one as well.
anthonyscardina is offline
Old 06-14-2018, 04:01 AM
  #1447
For most the biggest issue was ride height. If a chassis uses Associated style ride height inserts the rare #4 insert usually puts the rear pod right at 5.5mm with the tires. Front suspension is the easiest to shim but pay attention to the steering geometry.
old_dude is offline
Old 06-24-2018, 06:34 PM
  #1448
MCSRacing's Avatar
we all have had the CRC tires come unglued .. we just reglue them with AKA tire glue .. its the best out there and they will never come unglued after you hit with it .....
MCSRacing is offline
Old 07-18-2018, 11:09 AM
  #1449
The new Protoform Corvette ZR1 and the Kyosho Dodge Challenger SRT have been added to the body list.
dumper is offline
Old 07-20-2018, 12:06 PM
  #1450
Hi I'm new to RC/racing and trying to get started. I've visited my track and talked to some people and it seems like wgt-r would be a great class to start in and have fun. I'd also likely bash around at home in my neighborhood parking lot driving around improvised cone courses or something. Was hoping to find a 2nd hand roller or something to get started in case I find I don't have the time to put in to justify greater expenses, but not having luck so far and the itch hasn't gone away so I'm pretty close to just ordering the Gen-X 10 kit from Calandra. Also interested in F1 which is easier to find 2nd hand, but I've heard not as beginner friendly.
In the meantime I've been looking at all the body options for wgtr and was starting to wonder how much the body would matter in terms of competitiveness? I realize being new it will probably be quite some time before the body becomes the limiting factor in my lap times, but I was just wondering if there were some bodies that were better to use to learn with, or any I would want to avoid? I see there are quite a bit of bodies to choose from, but I always seem to keep reading about the same half dozen or so being recommended as the best/fastest/etc. I kinda like having something a little unique or different than everyone else is using, but not at the expense of making it harder than it need be while learning. The Ford GT was my first choice until I found out that was one of the popular choices.
I noticed many cars have rear wings, but some don't. Is anything without a rear wing going to be automatically worse off than anything with? I really like the Alfa Romeo 8c, and many of the muscle car/VTA bodies which don't have wings, but wasn't sure how much of a handicap not having a wing would be. Or for this class can any body be competitive if properly tuned? Or at least competitive enough that I wouldn't notice the differences until I've put in many many hours of practicing?
Thanks!
RCRhino172 is offline
Old 07-20-2018, 12:27 PM
  #1451
simple's Avatar
I mounted a JConcepts Layla to a VBC racing FX18;
Worked out quite nicely
VBC Lightning FX
simple is offline
Old 07-20-2018, 01:02 PM
  #1452
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
I have found that for X10/Roche style pods (instead of pill inserts), could benefit from threaded aluminum post spacers.
I luckily did not spend the money for X1 (F1) pods to convert my X10 '18. The problem with using regular spacers too high to get your desired ride height is they still shift around and the axle doesn't spin completely true. By using threaded aluminum spacers, they are centered and allow the rear axle to spin true while getting our desired height.
These threaded posts are all over eBay in various height sizes. I used some threaded 2mm tall nuts instead of spacers for the front end too. Everything is centered and doesn't move around.
Dan is offline
Old 07-23-2018, 11:22 AM
  #1453
Thanks!
I like the HPI Porsche GT1 #7038. It is pretty neutral on all surfaces. It's pretty durable and easy to paint. Great for learning.
Old 07-24-2018, 06:31 AM
  #1454
Do you guys find the rubber tire specific chassis to be better for this class compared to making a foam tire chassis work?
lowdoughracer is offline
Old 07-25-2018, 04:12 AM
  #1455
I have the CRC car and there is very little difference to make it a rubber tire car. They used the rear pod from their F1 car and made a chassis to accept that. The front end is different in servo position with more mounting options than their previous cars but the actual front suspension is what they have used on all their 1/12 and 1/10 scale pan cars for years. Their older cars that have inserted rear ride height adjusters just need the Associated #4 insert and spacers for the front to get them to proper ride height. I ran a older car for quite awhile and it worked very well.
One thing about their rubber tire kit is that you can position the battery inline or transverse with forward or back options in each configuration. It is the most tunable from that standpoint, just like their F1 car.
old_dude is offline
