World GT-R Rules and Discussion
#1231
Looks nice, rear wheels don't seem to protrude to much from the body! I am thinking of doing something similar but either with JConcept LMP body or WRC LMP body. The main problem is the fact these bodies are 190mm wide only, I guess a bit too narrow for the rear width of a 200mm pan car with CRC rubber tires
#1233
Best to go over to the CRC WGT-R string to see past conversations about servos.
Otherwise, I love the KO Propo RSx 12 servo and JR3650 servos I am using on my two cars. They center well and are very smooth.
Bill
Bill
#1234
I just got my first set of WGT- R tires. WHY did they make them such a BIG DIAMETER?? The front tires are HUGE!! The rears are like non-cut down foams--but they should be 1/4" smaller diameter front and the rears could be smaller too!! I've had to add big spacers under the front end to drop the ride height!! Geez, WHY???? It should be EZ to convert from foam to rubber--and bodies will be a problem to fit as well. WHY didn't CRC make the right diameter tires??
#1235
CRC did make properly sized tires for WGT-R. And the WGT-R bodies are different from the WGT bodies to accommodate the larger tires.
Looks like you need to do some research into the differences between WGT and WGT-R. I suggest that you thoroughly read the two threads about WGT-R in the Electric On-Road forums to understand the tire and body sizing issues related to converting a WGT over to a WGT-R car. I initially did the conversion of my first CRC WGT car and it went pretty smoothly...after I read Dumper's helpful posts about going that route.
Are you planning to use it for WGT-R on the carpet at TQ in Chino? Used to occasionally run WGT there; but, didn't know that they were running WGT-R these days.
You can PM me if you need help with your car conversion.
Welcome to WGT-R.
Bill
#1236
#1239
Thanks for the explanation Bill, but it still makes NO sense!!! Going to rubber tires should NOT REQUIRE a HUGE change in the WGT cars?? WHY?? What does it accomplish other than making it HARD on the guys that ran WGT to convert to rubber? Seems we don't have that large a participation in RC on road that making it a PIA for another class makes sense??? I'm okay with rubber tires if people want them--but it could have been a LOT smoother change for a fun class instead of painful!!
#1240
What huge change. On the older CRC SE car you added 8 2-3mm spacers in the front and rear.Put on the tires and a ton of bodies at one time to chose from (when HPI was making bodies). We still have more bodies to chose from than with WGT. It is a fun class for many of us racer here in Florida. No more ride height adjustments and no tire truing and the tires last longer.
#1241
The rubber rules use tired and tested rubber compounds that grip and wear well. Plus they never get close to any gluing problem. All in all they are the best tyre for my favourite class, and hats off to those that set the rules and chose them
Anything as small as thin foams would be a new size and design of tyre. I could speculate on how they might grip and wear, and that a new design would push up costs.
Let's enjoy what we have for a great class. And let's race!
#1243
99.9% of people running WGT-R are happy to be able to use an existing chassis and keep their investment alive.
Keep in mind that WGT-R didn't kill WGT, it was already dead. If you can still get guys in your area to run foam then great! I'd run both classes since I love pan cars and have 3 200mm GT chassis to choose from.
#1244
Those simple changes are all I've done to my SE to run rubber tyres
#1245
The only real change required is raising the suspension and motor plates so you can get ride height. For the pod, I simply run another pod plate cut down as a spacer and in the front, just run more spacers. It would be nice to have a low profile rubber tire that had grip like foam, but the existing Crc tires work fine and last a long time.
