Lipo's with 5mm plugs?
#16
Put some thought in some batteries are overkill, depending on your race class if you run 21.5, 17.5,13.5T or 10.5T you don't really want heavy batteries, 6400mah is ample with some brands weighing 295 grams to 305 grams, 7500mah or more could way 335 grams to 350 grams, 4mm bullets are fine, if you run mod maybe heavy is ok. That's just my opinion !!!!
#17
They come with a great punch and 310gr. I run with the connectors in front for better balance. Right to left balance is no problem.
#18
Guess it depends on your budget. If your a beginner though you won't notice any difference between a high dollar pack and a more budget friendly pack like the turnigy ultimates. Plus your racing stock and will have to replace your batteries about every 6 months to a year depending on how often you use them and how hard you are on them.
#19
The one thing I'm still a bit vague on is IR (internal resistance) and how to measure it, what is good and what is not and how does it affect performance.
Currently considering the Orca, Protek and the Intellect, but still not locked in.
#20
For me it was a benefit because I had only 1 battery with 4mm holes, so I don't have a bunch of packs just sitting around. I was relatively new when I started buying batteries and laying out my battery plugs so it was easier to go with the 5mm bullet plugs.
#21
Benefit of 5mm bullet plugs on batterys is very minimal not worth the effort more of a marketing ploy than anything else
#22
Team EAM
But in general the normal classes will never notice a difference.
EA
