Roche Rapide P12 1/12 Competition Car Kit
#1276
Sold.....
#1277
To run the side springs over the links do I need to shim up the chassis braces or just run as is?
#1278
I did run the car with the springs over the links some last season. I recall needing 4.0-4.25mm under the aluminum cross brace to space it up. As for the "effect", I would say that I was chasing something really small for black carpet. Because you locate the spring further away from the pivot, you need less spring. I went from a Roche White in the stock location to a CRC 45 over the link and felt nearly identical. What I felt it did though, was get deeper into the side spring and actually got a stiffer feel more into the throw.... if that makes any sense. At the time, I felt that increased exit steering. But it was only slight. It's not a huge "ah ha" change. I did run my cars that was at the last MHIC, 3rd in stock, so it didn't suck!
#1281
Sorry, I believe I worded that poorly. I'm looking for a complete (non USA Spec) P12 2017 kit.
Would anyone recommend that I simply just run the US spec car? I ran the Roche aluminum chassis on my 2016 and much preferred the carbon chassis on our track. I'm guessing I'd prefer the carbon chassis on the new car as well?
#1282
R/C Tech Elite Member
http://shop.rochercusa.com/index.php?route=information/contact
#1284
Yes it’s still for sale and I sent Pm to you.
thanks
thanks
#1285
SOLD......
#1288
See the link below.
https://www.facebook.com/HighvelocityRC/
#1290
Roche P12
Sold!!
