Roche Rapide P12 1/12 Competition Car Kit >
Like Tree196Likes
Old 12-09-2016, 07:01 AM
  #781
Trader Rating: 39 (100%+)
Seriously.............. I just built and ran the 2016 for a single weekend........
Jamie Hanson is offline
Old 12-09-2016, 07:32 AM
  #782
Suspended
Does anybody have a low to med traction setup for asphalt theyd be willing to part with?
xterray is offline
Old 12-12-2016, 04:15 AM
  #783
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Wes Raven has some asphalt setups.. you should search for them on FB or under ActivRC
hanulec is offline
Old 12-17-2016, 10:25 PM
  #784
petitrc.com
Arn0 is offline
Old 12-23-2016, 05:31 AM
  #785
Trader Rating: 24 (100%+)
The Xenon VSS front end replacement parts are direct replacements, correct? Roche has been OOS on the upper arm for over a month and just went OOS on the spindles. Would like to have some spares! Are these the correct parts? Thanks!
Upper arm - http://www.tqrcracing.com/shop/produ....asp?p_id=9384
Steering knuckles - http://www.tqrcracing.com/shop/produ....asp?p_id=9380
fenton06 is offline
Old 12-23-2016, 07:15 AM
  #786
Korey Harbke's Avatar
Yes, Xenon VSS plastics are direct bolt on.
You can also check out Apex RC for Roche parts. They usually have a good stock of products for the P12.
-Korey
Korey Harbke is offline
Old 12-23-2016, 10:43 AM
  #787
hanulec's Avatar
Youll find most people move to the HARD plastic options...
hanulec is offline
Old 12-23-2016, 02:39 PM
  #788
For everything? I run on the gray carpet and am going to get hard lower arms to help combat the pivot ball getting sloppy, but if all plastic pieces should be hard I'll just keep the normal ones as spares.
fenton06 is offline
Old 12-23-2016, 03:45 PM
  #789
hanulec's Avatar
Hard lower arm for sure
Camber usually fixes any push issue on low grip carpet
hanulec is offline
Old 12-23-2016, 05:11 PM
  #790
What are your thoughts on hard upper arms/caster blocks/knuckles?
fenton06 is offline
Old 12-23-2016, 05:13 PM
  #791
hanulec's Avatar
Most run them...
hanulec is offline
Old 12-23-2016, 05:27 PM
  #792
MontanaMaxx's Avatar
Hard is the way to go I have 2 that way need to put hard on my 3rd
MontanaMaxx is offline
Old 12-23-2016, 05:56 PM
  #793
hanulec's Avatar
I usually start a kit with just hard low arm and awaiting other incidents to change the rest of the parts
hanulec is offline
Old 12-24-2016, 06:45 AM
  #794
pphaneuf's Avatar
From the sound of it, they're not super-critical, "must have" items, but if you break one and it needs replacing, get the hard parts?
pphaneuf is offline
Old 12-24-2016, 10:25 AM
  #795
hanulec's Avatar
Hards are more popular 3-4 to 1
It's all mental
hanulec is offline
