Like Tree256Likes
Tamiya TRF419
Old 12-09-2019 | 08:00 PM
  #4501
Raman's Avatar
Originally Posted by Red141
Bringing this back up from June... What is the part number of this bumper?
This is the one
https://www.tqrcracing.com/shop/prod....asp?p_id=1862
Raman is offline
Old 12-10-2019 | 07:31 AM
  #4502
Originally Posted by Raman
Thank you!
Raman likes this.
Red141 is offline
Old 12-13-2019 | 12:07 PM
  #4503
I just received my TRF419XR with aluminum chassis that I purchased from a forum member here. Wow, this thing is so light compared to my TB Evo.7. Quick question, how do I mount the ESC and receiver? With the holes in the chassis, the area for the servo tape is so small.
Red141 is offline
Old 12-13-2019 | 12:09 PM
  #4504
Dan's Avatar
Dan
If you get good double sided tape, it will hold fine. I never had issues on my Xray flex chassis.
Red141 likes this.
Dan is offline
Old 12-13-2019 | 01:17 PM
  #4505
Raman's Avatar
I stopped using double sided tape. I use E6000 glue instead. You can also use shoe goo or goop. Saves you for having debris picked up by exposed tape
Raman is offline
Old 12-13-2019 | 04:28 PM
  #4506
Thanks for all the replies to my noob TRF419XR owner questions. I promise that I am searching prior to asking.
Here is one more... I will be using the aluminum chassis (black carpet) without the center ballast weight - it didn't come with it and I can't find any for sale. My question is, how do I prevent the rear of my Lipo from moving laterally and rubbing against the pinion. Because of all the holes on the aluminum chassis, I can't use 54694 Rubber Anti-Slip Sheet. Is the strapping tape enough to prevent any movement?
V8 Rumble likes this.
Red141 is offline
Old 12-14-2019 | 11:48 AM
  #4507
Raman's Avatar
this is the link to the ballast weight
https://www.tamiyausa.com/shop/7-dig...-weight-42317/
i would still cut strips of the anti slip sheet and place it on areas you can.
with these in place, and battery tape you should be good to go.
a good upgrade would the L shaped battery holders which are not cheap..
https://www.tamiyausa.com/shop/7-dig...mount-a-42315/
https://www.tamiyausa.com/shop/7-dig...mount-b-42315/
Raman is offline
Old 12-14-2019 | 08:11 PM
  #4508
Thanks once again Raman. I wonder why TamiyaUSA didn't come up via Google. I'll remember to look there too the next time.
Red141 is offline
Old 12-14-2019 | 08:30 PM
  #4509
Raman's Avatar
The manual has 5 digit and 8 digit part numbers. You need to drop the 1st number and then do a search. No idea why it’s like this.. but it’s been this way for decades
Helios and Red141 like this.
Raman is offline
Old 12-16-2019 | 08:23 AM
  #4510
Hey Bud,
Where are you located? I have a center weight left over from my 419x I'd be happy to pass along if the shipping is cheap.
- Jose
P.S. Anyone interested in some aluminum pulleys and diff housings? No REASONABLE offer will be refused... and I'm very reasonable. I switched to the 420 Diff housing and I'm not going back to these.
C van der Hagen and Red141 like this.
ittjv is offline
Old 12-17-2019 | 09:08 PM
  #4511
Default 420 on the way not sure if it's his last hooray or if I end up hanging on to it.
I do love this guy!
Qatmix likes this.
Gyr0 is offline
Old 12-18-2019 | 02:01 AM
  #4512
You are going to love the 420. It’s a pretty big step up. Although I am not letting my 419 go anywhere.
Qatmix is offline
Old 12-18-2019 | 06:26 AM
  #4513
you can stick the anti slip sheet on each of your batteries.(of course u need to buy extra anti slip sheet)
or i will make a 3d-print dummy center ballast weight because i need to reduce weight in blinky race
tommy1030 is offline
Old 12-19-2019 | 02:27 PM
  #4514
Have you tried it yet?
hipwell is offline
Old 12-19-2019 | 04:24 PM
  #4515
Yep, I’m finishing the review for the site now. I’ve smashed my track records with the new car. It has way more steering.
Qatmix is offline
