Like Tree256Likes
Tamiya TRF419
Old 01-26-2020 | 01:36 PM
  #4531
Hello everybody,
first of all, I apologize in advance for the english mistakes in the following text. I am french, and I am not fluent in English...
I am finishing the build of a TRF419XR, but I have an issue with my front belt:
It seems to run too close to the blue servo mount, as well as to the center carbon stiffener.
Depending on the position of the belt on the center and front pulley, (there an approx. 2mm latteral play) the belt is sometimes in contact with both the stiffener and the servo mount.
The blue color on it already started to come of from just a 10 second wheel spin in the air, when I was testing the electronics.
Did you guys already experience this problem? Is it supposed to be fine like that on this car ? (Which I seriously doubt...) Or do you think I made mistake at one point during the build ? Can it come from a lack of tension on the belt ? ( Following the manual settling, the belt was feeling way to loose, so I already re-tensionned it a little bit. It feels totally OK right now. )
Thank you very much for your help !
LeSournois is offline
Old 01-26-2020 | 04:11 PM
  #4532
LeSournois After reading your post I went to check my XR and lo and behold, my servo mount show signs of the belt rubbing. I agree it is because of how wide the front pulley is. I have part #42309 37T Aluminum One-Way Pulley that I have not installed - it is 1.3mm narrower than the stock front pulley. Perhaps that will solve this problem. I haven't installed it because I race USGT and want a lighter drivetrain. I'll keep an eye on it to see if it gets worse.
Red141 is offline
Old 02-07-2020 | 09:54 PM
  #4533
Got a 419X, and havent had any issues with the belt rubbing the servo mount, but it does look a bit too close. Might be because ive shimmed the center pulley
herrokero is offline
Old 02-08-2020 | 02:55 AM
  #4534
Raman's Avatar
It rubs, you just have to live with it
Raman is offline
Old 02-11-2020 | 08:46 PM
  #4535
thirtydaZe's Avatar
thirtydaZe is offline
Old 02-26-2020 | 09:43 PM
  #4536
KREATOR1's Avatar
Hi all, Just 1 quick question, does the 419 rear diff same as the 417?
KREATOR1 is offline
Old 02-27-2020 | 07:05 AM
  #4537
JoeyE's Avatar
KREATOR1 likes this.
JoeyE is offline
Old 02-27-2020 | 07:07 AM
  #4538
JoeyE's Avatar
They are both 37T but the spacing might be off a bit. I installed a TB04 rear gear diff on my TRF414 so anything is possible~!
JoeyE is offline
Old 02-27-2020 | 07:09 AM
  #4539
It’s the 418 diff, but the old white 417 one will fit
Qatmix is offline
Old 02-27-2020 | 07:19 AM
  #4540
JoeyE's Avatar
TRF418 part number if needed. Hummm, TRF418 and TRF419 are the same part number. Did not know that.
JoeyE is offline
Old 02-27-2020 | 07:27 AM
  #4541
JoeyE's Avatar
This information will be a good note:
JoeyE is offline
Old 02-27-2020 | 08:55 PM
  #4542
KREATOR1's Avatar
thank you all for the info. appreciate it..
KREATOR1 is offline
Old 02-27-2020 | 08:58 PM
  #4543
KREATOR1's Avatar
Wink
This really help , because i have few 417 spare diff. thanks
KREATOR1 is offline
Old 02-27-2020 | 10:15 PM
  #4544
rc_square24's Avatar
The bulkhead distance should also be checked, in this case it is the same (I'm not sure if they changed through the iterations of the TRF417.
Below is what I gathered from the internet, for reference:
417 v5 22mm
419 24mm
419X / XR 22mm
420 20mm
rc_square24 is offline
Old 02-29-2020 | 10:39 AM
  #4545
If anyone based in the US is interested in a 419XR that just hit the marketplace:
Tamiya 419XR TCS Spec carpet build RTR
madjack is offline
