Like Tree256Likes
Tamiya TRF419
Old 07-31-2017 | 12:01 PM
  #3481
F N CUDA's Avatar
Originally Posted by tobyzhang
Honestly Cuda, people say Xray shocks are the best but it has the same amount of o-ring stiction as tamiya shocks with the clear o-ring. Trust me, just use the clear o-ring unless you want to rebuild every run. The blue is smoother but you have to use 3mm shims to increase pressure a bit so it doesn't leak as bad. But I think the clear o-ring is the way to go. I can't really feel any difference on track between the two o-rings.
Just trying to get every advantage available
Like they say, setup is not overrated
And if I can stumble onto the monkey car setup (a monkey could drive it fast) like I did with my F1 cars, then maybe I can be competitive against drivers that are better than me in this class too.
F N CUDA is offline
Old 07-31-2017 | 12:59 PM
  #3482
CL's Avatar
CL
Cuda,
The thing that is holding you back is your motor. It's time for a new V16.
CL is offline
Old 07-31-2017 | 01:33 PM
  #3483
nubs's Avatar
I would say build two shocks, one with each method and then put them in a bag and shake them up. Pull them out and see if you can notice a difference. Go with the way that feels better.
nubs is offline
Old 07-31-2017 | 02:31 PM
  #3484
F N CUDA's Avatar
Originally Posted by CL
Cuda,
cant use it til it handles right
horsepower wont help me without handling
have had old stuff in my good handling F1 for looong time gettin it done
running old battery and 13.5 motor now as a kick ass 17.5, and still off the pace with TC
got the new stuff standing by but why beat up the new stuff during growing pains?
getting there tho, starting to sweat the small stuff.
F N CUDA is offline
Old 07-31-2017 | 02:39 PM
  #3485
F N CUDA's Avatar
its noticeable, but just a little so thats why im trying it.
does it matter?
probably not but peace of mind can build confidence in us mere mortals
F N CUDA is offline
Old 07-31-2017 | 03:02 PM
  #3486
Hi guys,
i´m new in this forum.
What i can say is that i´m using the clear o-rings from tamiya now. With the blue o-rings included in the kit, shocks are leaking. Then i´ve tried the x-rings. Shocks are leaking. In my case, it doesn´t matter if i using shims or not. The shocks are leaking and after one race day, i have air in it. Since i have build it with the clear o-rings, i have no problems with it anymore and they work very good. My shocks are leaking free after three race days.
Roland83 is offline
Old 07-31-2017 | 04:20 PM
  #3487
nubs's Avatar
Originally Posted by Roland83
Hi guys,
Same here, except I went one step farther. I also got the reinforced black rod guides. To get even more consistent feel, I also drilled a hole in the plastic piece of the top cap.
nubs is offline
Old 08-02-2017 | 12:56 AM
  #3488
Simmi's Avatar
It comes the new EVO 7 with the same damper of the 419X.
Wonders how the plan of the damper looks. I'm curious if Tamiya fixes the flaws of the dripping shocks
Simmi is offline
Old 08-02-2017 | 08:23 AM
  #3489
nubs's Avatar
All they would need to do is change the orings that come with the kit, but I doubt they will have changed that.
nubs is offline
Old 08-02-2017 | 10:25 AM
  #3490
Simmi's Avatar
@nubs
Why does Tamiya do that?
Which have also taken the leaking diff from the TRF 419 or the Problems with the C-Hub ...
Is Tamiya really interested in correcting errors?
Not really business-promoting
Simmi is offline
Old 08-02-2017 | 10:44 AM
  #3491
tobyzhang's Avatar
@nubs
Feel like the new engineers and production guys at tamiya are less well versed in tolerance control than their predecessors. The C hub has more slop than the older ones and the shocks leaks way more than the older TRF shocks as well. Not to mention the M07 needs lots of sanding to get binding free suspension for both the front and the rear. We understand to fix tolerance for a injection molded part will cost Tamiya a lot of money because the tooling will have to be altered. But still man, the older stuff are showing better fit.
The O-Ring I feel I can't really blame Tamiya. Those for sure are parts made by third party but Tamiya should still give solution to make the o ring work with their hardware better. I tried the 0.15 shim and it works pretty well actually.
The overall mechanical design are still very good and the machining are still top notch. But someone is definitely slacking in the tolerance department.
I did notice better tolerance in the 419X arms though so maybe they did try to improve things at least for the newer toolings.
tobyzhang is offline
Old 08-02-2017 | 11:45 AM
  #3492
nubs's Avatar
@nubs
If I am being honest I think its because Tamiya is a large company that has a lot of different products ( i mean many different types of products from models and slot cars to the RC cars we love). They have to be very careful about what they choose to do because it will take capacity away from other products they are making.
nubs is offline
Old 08-02-2017 | 11:48 AM
  #3493
nubs's Avatar
The other problem is that they are using existing molds for new materials. When the materials cure, they don't cure to the same size as the other types of plastics. This is what causes the slop or binding. I don't actually mind slop that much because slop is created over time through friction, you can generally offset slop with shims.
nubs is offline
Old 08-02-2017 | 02:24 PM
  #3494
Raman's Avatar
Just use the damn clear o rings on the shocks like the rest of us and you won't have to worry about them
Raman is offline
Old 08-02-2017 | 05:08 PM
  #3495
F N CUDA's Avatar
looks like we've all got it figured out for them
F N CUDA is offline
