Like Tree146Likes
Tamiya TRF419
Old 08-17-2017, 04:40 AM
  #3511
Tom1977's Avatar
Originally Posted by Simmi View Post
Has anyone try the Arrowmax Spur Gear?
Can buy some 48dp with 78 teeth.
Have them in 64dp. Fits very well in 419x. They are kind of carbon reinforced plastic (hard).
Tom1977 is online now
Old 08-21-2017, 02:02 PM
  #3512
Has anyone been able to find the 419x ws aluminum chassis or 1.75 mm upper deck anywhere?
Kelseyrc is offline
Old 08-21-2017, 11:55 PM
  #3513
Raman's Avatar
Trader Rating: 60 (100%+)
Default Flange Tube
What do you guys use for the flange tubes on the steering upright?
I have always kept the old 54075 TB-03 in my spare parts, but it looks like its being discontinued.
So I looked up the parts in the 419 / 419 x manual and
418 / 419
1. 19804382 4.5 x 4.0 upper flange
2. 19804396 4.5 x 4.7 lower flange
3. 418 still uses this under the upper flange 198056455 3x.07, since it uses the IFS up right
4. 419 doesn't user an upper spacer
419x
1. 19804942 4.6 x 3.9 upper flange
2. 19804943 4.6 x 4.4 lower flange
3. 53539 5.5 x 0.5 spacer on top of upper flange or 198056455 3x.07
The ones that are in the old 54075 TB-03 are different dimensions as well.. only thing consistent the 5x9 ball stud and the 3 x10 counter sunk screw
So Flange me.. I'm confused what to use..
Raman is offline
Old 08-22-2017, 03:11 AM
  #3514
It is pretty hard to buy them. I have to turn them on a lathe with better clearance. If you have access to lathe it is 20 minutes job using brass rod.
Macio4ever is offline
Old 08-22-2017, 01:03 PM
  #3515
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by nubs View Post
My problem with 48p is getting down to 3.2 fdr. It's been difficult to find a brand that has teeth at around 65 that also have the right fit for the pulley.
Not sure of the hole pattern but Arc 48p spurs are very thin;
https://www.tqrcracing.com/shop/prod...&s_maker_id=98
MikeR is offline
Old 08-22-2017, 01:49 PM
  #3516
Tom1977's Avatar
418 / 419
419x
The 419x flange tubes have less slop as the older versions. They are interchangeable.
Old 08-22-2017, 02:05 PM
  #3517
Tom1977's Avatar
Where are you located? In Germany you can buy both regular as spare parts.
If you are located in the U.S. I would suggest rcmart.com (aluminium lower in stock).
Old 08-22-2017, 03:14 PM
  #3518
nubs's Avatar
Hey Mike,
The pattern has to be perpendicular instead of diagonal like the Arc. I think I may have to switch over to 64P because I don't think I can achieve the range of FDR that I need with the 48P.
nubs is offline
Old 08-22-2017, 04:32 PM
  #3519
I am in the US. I've only been able to find the 419 aluminum chassis on RC Mart. Do you know if the 419 chassis fits the 419x?
Kelseyrc is offline
Old 08-22-2017, 09:47 PM
  #3520
MikeR's Avatar
Hey Mike,
Sounds like Tamiya needs to work on an option pulley for extra gear choices
MikeR is offline
Old 08-23-2017, 07:22 AM
  #3521
nubs's Avatar
Agree with that assessment.
nubs is offline
Old 08-23-2017, 10:52 AM
  #3522
Tom1977's Avatar
No because the bulkheads are more narrow in the 419x.
In Germany you can get both lower and upper XWS deck @ modellbau-seidl.de
But they have no official option for international shipping anymore! I think Tamiya distribution blocked that. But you're free to ask them for intl. shipping.
Old 08-23-2017, 11:46 AM
  #3523
Tom,
Thanks for the info! That's a bummer that I can't use the 419 lower deck and that Germany is the closest option for me... It seems like it is getting harder to get parts for 419x in the US as a lot of parts are out of stock. I somehow cracked my upper deck and am having the hardest time finding one in stock anywhere...
Kelseyrc is offline
Old 08-23-2017, 12:13 PM
  #3524
One small discovery about suspension arms in 419X. Some of you has reported slop on the arms developed quickly. It happens but seems that slop is not on the hinge pins. If you loose screws on suspension mount (one piece) and tighten it again it will be ok till next hit.
Old 08-23-2017, 02:52 PM
  #3525
CL
CL's Avatar
Trader Rating: 33 (100%+)
Just drill a couple of holes on the spur gear, and you will be good.
CL is offline
