Tamiya TB Evo 6
#1516
Looks great. What companies white ball caps are you using? I would like to run those too.
Also the front of the car seems to have a lot of flex. I want to try and stiffen it up a bit, but without going to the aluminum chassis. I am running solid hinge blocks already. Any other suggestions?
As for removing 3mm from the outdrives, I just cut the channel 3mm deeper with a grinding wheel on a dremel. I figured that this was hardened steel, and I am running 25.5 and 21.5 motors. Removing the material shouldn't hurt the strength for my application.
#1517
I'm lost, when using the Exo6 conversion the internal ratio changes? Or is it still 2.5?
#1518
The white cups are from Square.
Think it completes the look of the car
#1519
#1520
Thanks.
I don't the ratio changes when you use the conversion. I'm still operating off of the 2.5 ratio. Changing the motor layout doesn't alter the final ratio. The transvers gears are a 1-1 ratio. Removing them only removes the rotating mass and energy loss due to directional changes
#1522
#1525
My bad guys, in my case it's 2.43 as I'm running Spec R diffs.
#1527
Looks great! Ford GT is very popular in a17.5 GT Class here in Germany.
#1529
https://www.tamiyausa.com/articles/s...?category_id=7
#1530
