Xray X1 - Formula One Car >
Like Tree366Likes
Old 06-11-2018 | 07:16 AM
  #2581
Dan's Avatar
Dan
What I noticed when people have this issue is they got the screw in too tight. (the screws that go inside the pivot balls and screw into the camber inserts)
I have aluminum pivot balls and the aluminum camber inserts so I can torque them down more and it will still allow the arm to move smooth. Just be careful with the stock all plastic setup since its easy to over-torque it and cause binding.
Dan is offline
Old 06-13-2018 | 09:18 AM
  #2582
Dan, are the aluminum pivot balls an Xray part? I didn’t see it in the manual.
Sean B. is offline
Old 06-13-2018 | 10:00 AM
  #2583
Dan's Avatar
Dan
Radtec makes them (same company as Roche). I wouldnt be surprised if the Roche F1 pivot balls are the same.
Sean B. likes this.
Dan is offline
Old 06-14-2018 | 03:22 AM
  #2584
sbd
Absolutely the same albeit Radtec are a bit cheaper. Much better choice than the original plastic balls.
sbd is offline
Old 06-18-2018 | 10:32 AM
  #2585
Dan's Avatar
Dan
Red RC ? RC Car News » Xray pan car gear differential sets
The Xray gear diff is finally here. Probably a lot lighter than the Fenix diff.
Dan is offline
Old 06-18-2018 | 11:00 AM
  #2586
If it does not leak, it's going to be a winner!
Martin Paradis
rhodopsine is offline
Old 06-19-2018 | 07:18 AM
  #2587
I’m building a new kit, got the radtec balls. Four of them are really tight inside the plastic cups. Any tips to free those up? Pinching them with pliers may be tricky.
Sean B. is offline
Old 06-19-2018 | 01:20 PM
  #2588
Use your reamer to slightly open the holes in the carbon arm.
chensleyrc1 is offline
Old 06-19-2018 | 01:51 PM
  #2589
sbd
Its 39,5g ready to run. The original part is 36g.
Absolutely worthwhile upgrade. This time the promotional text is fully justified!!
sbd is offline
Old 06-19-2018 | 03:29 PM
  #2590
The balls are tight in the plastic cups, I don’t have them in the arm yet.
Sean B. is offline
Old 06-19-2018 | 05:07 PM
  #2591
JayL's Avatar
R/C Tech Elite Member
Then they may be free enough with the weight of the arm/suspension on them, install them in arm. I never had any issues running the radtec balls in my xray, when I had it.
JayL is offline
Old 06-19-2018 | 06:26 PM
  #2592
Dan's Avatar
Dan
And it is only $80 too...which is pretty reasonable when you start adding up the cost of replacement rings, diff balls, thrust bearing, etc over time..
Dan is offline
Old 06-24-2018 | 10:53 PM
  #2593
what spur gear does it come with stock?
Trampsinger is offline
Old 06-25-2018 | 03:01 AM
  #2594
PDR's Avatar
PDR
80T according to this: https://www.teamxray.com/teamxray/sh...?file_id=13190, with options for 76-92 in 4 teeth increments.
Trampsinger likes this.
PDR is offline
Old 06-25-2018 | 09:24 AM
  #2595
anyone running spool on their X1 on black carpet yet
phatboislim is offline
