Xray X1 - Formula One Car >
Like Tree129Likes
Old 06-25-2018, 10:00 AM
  #2596
Dan
Dan's Avatar
Trader Rating: 53 (100%+)
Yes....and loving it.
Dan is offline
Old 06-26-2018, 10:27 AM
  #2597
bdmpastx's Avatar
Originally Posted by phatboislim View Post
anyone running spool on their X1 on black carpet yet
Yes, it is even better than in my 12th. I think the rubber tires love it more than the foams do. It isn't as sensitive to throttle inputs as it is on the 12th so it is easier to drive. The 12th took some getting used to at first. but I love them on both now. I dropped my lap times 7 tenths by going to the spool. The only thing that has been a downer was chewing teeth up on spurs when a crash happens. Since the rubber doesn't slip, it would break of teeth when they hit the ground under throttle. I had another racer clip me and it happened 2x in the same day. The motor didn't move, it just chopped teeth off.
bdmpastx is offline
Old 06-26-2018, 12:57 PM
  #2598
Dan
Dan's Avatar
I must agree as well. For rubber tires, it is quite noticeable over the Fenix diff/ball diff on high traction black carpet. I honestly did not have to change much in my setup and it was still very drivable. Geared a bit taller due to the lightness of the spool. Very fast. I will be going to a spool for my WGTR car too.
1/12 spool was a different story. Very tricky to drive. After making some setup changes to soften all my springs, it was more manageable, but still a handful on 13.5 power. The xray gear diff should be interesting. It is lighter than the Fenix diff and should be interesting to test in F1.
Dan is offline
Old 06-27-2018, 09:54 AM
  #2599
Trader Rating: 21 (100%+)
what's yall setup running that spool? like i put the spool in and for the first time finally put 3* toe out on the front to get turn in and the car turns in....but it just seems....something feels edgier. but i feel if i take the toe out i wont have the entry steering anymore. my ackermann is set to the most aggressive way to get the entry steering. so i'm just here for setups...
i do love the spool in my 12th a whole lot too tho. just trying to figure out how to gear that thing with it in
phatboislim is offline
Old 07-09-2018, 11:57 AM
  #2600
Is the Xray gear diff compatible with the '16 X1? Amain shows it is only compatible with '17, '18.
Can anyone confirm?
tekin112000 is offline
Old 07-09-2018, 12:47 PM
  #2601
Dan
Dan's Avatar
phatboislim, what springs and side damper oils are you running? Tires and how much front sauce?
tekin, it will fit.
Dan is offline
Old 07-09-2018, 01:42 PM
  #2602
Can anyone confirm?
Straight from XRay web site
https://www.teamxray.com/teamxray/products/prodspec.php?prod_id=6873&kategoria=0&catName=
Martin Paradis
rhodopsine is offline
Old 07-10-2018, 09:41 AM
  #2603
tekin, it will fit.
i've made some changes to test out, but i was running usually the gold mediums i think for side springs, 10k tubes and gold softs up front w/ a 2.2 center spring
Old 07-11-2018, 02:15 AM
  #2604
Ph3nyx's Avatar
Xray gear diff montage
+ YouTube Video
symmetricon likes this.
Ph3nyx is offline
Old 07-11-2018, 02:51 PM
  #2605
Trader Rating: 29 (100%+)
Does I am missing a thread or nobody talk about this new xray gear diff ?
curious to read some feedback and what cst was used on black carpet...
pat5b is offline
Old 07-11-2018, 03:07 PM
  #2606
Dan
Dan's Avatar
I think I read somewhere people are using 20k CST on black carpet 25.5 racing.
My Xray gear diff is still unassembled. RC America says the gear diff carbon shaft might be a few weeks away to arriving. I'm in no rush, preferring the spool setup so far.
Of course Xray didn't include a carbon shaft, more $$$ for you to spend.
iTz Nicholas72 likes this.
Dan is offline
Old 07-11-2018, 03:11 PM
  #2607
Dan
Dan's Avatar
My spool setup is 6 deg caster, 1-1.5 degree toe out. 1.5 front spring and 0.6 side spring.
The gold 0.9 side springs can make the car feel edgy with the spool.
Dan is offline
Old 07-11-2018, 03:24 PM
  #2608
I refilled mine 3 times before found the action/ feeling I wanted 10k as listed in instruction sheet 30k and ended with 60k for first practice and loved it
I usually run a Fenix gear diff with 2.5m
I just buy a second xray diff to test with maybe higher cst!
pat5b is offline
Old 07-17-2018, 06:00 AM
  #2609
Battery recommendations for X1 2018?
jevs is offline
Old 07-17-2018, 09:49 AM
  #2610
i run fantom personally. if i buy another, it'll probably be PCR
