Xray X1 - Formula One Car >
Like Tree305Likes
Old 05-16-2018, 08:29 AM
  #2566
DirkW's Avatar
Originally Posted by Tim Neja
You can leave the battery in and run all day on it.
Depends. Many places require you to charge in a lipo bag, not in the car. So, leaving it in, might not really be an option.
DirkW is offline
Old 05-16-2018, 10:57 AM
  #2567
It's tricky bleeding the shocks per the manual, it takes some practice and I don't rebuild them enough to get it right every time.And if you do it wrong, you introduce air back into the shock.
If I still have some rebound, I'll turn the shock upside down, unscrew the bottom cap, slide the cap up and push the shock shaft slightly to the side. Excess oil will come out past the O rings, but no air will go back in. Not my idea, I found it in a video while trying to figure it out, just like you.
belewis01 is offline
Old 05-16-2018, 02:51 PM
  #2568
Default Volante tires setup
Hi guys.. I have used Volante Ets tire compound, medium in front and super soft in rear. . No good result because i lost the rear during long corners with xray x1 car....
Someone have a good basic set up for this tires with 25/30 ° Celsius on asphalt? I would like to understand these tires... On the same track with ride gr the car was quite good...
Thanks in adavance!
Marco Donadelli is offline
Old 05-17-2018, 06:49 AM
  #2569
--> Will try this method, thanks!
Originally Posted by carrizojim
I learned from this Alexander Hagberg video....
--> So, zero rebound is preferred then? I saw that video, that's where I first heard it, but that's a TC race on carpet, so wasn't sure it could be translated to F1 center shock + on asphalt.
I will try it, but am still kind of confused with the zero rebound thing​​​​. Isn't it just working the spring then?
--> This + then I would spend more time waiting on a charging battery than driving, whereas when I bring 3 batteries, I can just let everything cool off put in a new battery and go. I won't get around to driving as much as I would like so want to make the most of it. Do most of you run 1 battery the whole time?
Originally Posted by Adamska27
Stinj - You need to bleed more oil out of your center shock if you can't compress it fully as you said, side shock sounds like it is OK
I don't run the inline battery, I'm no help on that
--> thanks, i'll put in the side shock like it is then.
Stinj is offline
Old 05-17-2018, 09:15 AM
  #2570
carrizojim's Avatar
Not really, it helps if you aren’t getting enough droop, which on this car isn’t very much anyway. Also, it’s not going to change the dampening, that’s controlled by the holes in the piston and weight of the oil. On a bumpy track some rebound will help. I like my cars a little on the soft side. I race outdoor asphalt, but it’s pretty smooth. I run zero rebound on my TC, works awesome, car is on rails, not so much my driving though😂
carrizojim is offline
Old 05-17-2018, 09:40 AM
  #2571
Here's another shock building video - it's for the 2018 ULP shocks, but I tried it yesterday for my 2017 SLP shocks on my T4 ( same as X1 shocks ) and it worked perfectly. The trick is to push the membrane down about 2-3 mm then pull the shock shaft down before putting on the cap.
X Ray shock build
I always build for zero rebound, it's easy to be consistent that way, and if you look at the pros setup sheets, it's normally at zero as well.
X1 setup sheets
Old 05-18-2018, 03:18 AM
  #2572
X Ray shock build
X1 setup sheets
Followed this video and shaft goes in all the way now + zero rebound. Will start with this.
Just need to do some rewiring + fiddle with the esc and the transmitter and then I'm finally ready for the track.
Checking some measurements in the meantime. Found the camber to be off left VS right. Luckily found a post by searching this thread to unscrew the top plate and wiggle it a bit until it's the same left/right. Sloppy business.
Last edited by Stinj; 05-18-2018 at 03:28 AM. Reason: was asking where to measure ride height but found a post on it
Stinj is offline
Old 05-28-2018, 12:59 PM
  #2573
For the 18 car, carbon chassis or aluminum flex for carpet?
Sean B. is offline
Old 05-28-2018, 01:41 PM
  #2574
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Aluminum flex unless you are running on really low traction non-CRC carpet.
Dan is offline
Old 05-28-2018, 05:44 PM
  #2575
Low to medium traction on grey carpet. Sounds like carbon will be good enough for now.
Sean B. is offline
Old 05-29-2018, 09:41 AM
  #2576
Trader Rating: 26 (100%+)
for the record...i did run a solid aluminum on a super low traction grey carpet. most of my issue was diff and punch setup. aside from that i just ran the car close to the same. felt generally solid. I also didnt make the changes necessary to make it easier to drive that i mentioned so....
aluminum, if that's already what you have if you're running on low traction (aside from asphalt, which i cant speak on) is fine
Sean B. likes this.
phatboislim is offline
Old 06-08-2018, 07:24 AM
  #2577
Adamska27's Avatar
For tarmac I'm going back to the ball diff I think, that's what everyone is using on asphalt right?
Gear diffs pretty much only on carpet right?
Thanks to all for input
Adamska27 is offline
Old 06-08-2018, 09:41 AM
  #2578
Dan
Dan's Avatar
Yeag, ball diff for asphalt. Tried gear diff on asphalt before and did not like it.
Dan is offline
Old 06-09-2018, 10:54 AM
  #2579
SpidarX's Avatar
I'm building an X1'18 and I noticed that the upper arm bushings are tight. The arms do not fall down under their own weight (before attaching steering block). Is there a way to free this up, or is is supposed to be tight?
SpidarX is offline
Old 06-11-2018, 06:17 AM
  #2580
bdmpastx's Avatar
Billy, There could be several reasons. It can be that the plastic balls and screws are too tight because the holes in the carbon are too small for the holders. That could put them in a bind. Mine do move freely. You can heat the balls and cups with a blow drier and move them up and down until they are free. Also the balls in different locations are slightly different shapes. Some have a collar on both ends and some only on one side. You need to make sure you have them in the right location and orientation. BTW, glad you got one. I have really been enjoying it. I got mine dialed in really good. If you come to Newman's I can help you out. If you come there, you have to have a spool to turn fast laps. Otherwise you will be diffing out in every corner. Cristian, Marcus and myself had some insane close battles. It is pretty fun finishing so close because they are all so evenly matched..
bdmpastx is offline
