HoBao H4E Pro touring car kit
#212
Lou Vanderwey smashed Circuit 15 Stock TC and Mod TC Track Records with his Hobao cars today at Lou's Speedway near London Ontario Canada today.
#214
#215
H4e took the win for 17.5 sportsman and 13.5 expert sedan classes for our local club race today!
#216
wonder if hobao will be doing the rear support plates in different thicknesses to change the rear flex and grip
#218
From this site:
http://its1204.com/content/ofna-h4e-build-tips
..is anyone wrapping their drive shaft joints w heat shrink?
#219
From this site:
#220
On a related note, a few locals have reported breaking DCJs on hits with extreme angles. I haven't had this issue, but the going theory is that the steering angle is too extreme even for DCJs. This can probably be helped by reducing the dual rate a bit to take out a little steering throw.
If the ball cups are really tight, you can squeeze them lightly with a pair of pliers as Olly Jefferies noted here for his TC6 build tips guide: http://www.petitrc.com/reglages/asso...TC6_BuildTips/
#221
What are you guys using to lube the cvas?
I used a bit of grease but now its mixing with dirt
Do you guys run them dry?
#222
Wurth HHS-K
#223
Looks like some good stuff
Is it available locally or do you order it online ?
#224
Just got my hands on one from Demon Products in the UK @ £270
Will start off the build later. Am I correct in saying in order to get 4 degree kick-up that it is done via caster on the front block rather than different C-Hubs?
If so how many shims need to be under the front block?
Thanks.
Thanks.
#225
I wrote that article. I never wound up wrapping my DCJs with heatshrink and the car has been fine.
As for wrapping my joints w/ heat shrink tubing, I think I will pass. If the retainer clips aren't popping off then I don't see the point in adding something that will be an extra step to remove and put back when I rebuild/check/clean the joints. By the way, the clips are a bit of a PITA to get back on. I can get them on, but they take about 5mins of struggling w/ and some chipped up fingernails to get them back in place.
Is there a quick trick to get the clips on? Are you guys using a special tool or something?
