Like Tree11Likes
Tamiya TB04 Pro
Old 09-18-2013, 12:54 PM
  #106
Trader Rating: 54 (100%+)
Originally Posted by bizkit1
That kind of sums it up, might be an upgrade coiming out later or use a hop up from another kit.
no not really tamiya never shows an entire gear chart ......so unless you own one who knows what will fit you cant figure what mods will work by looking at a manual
rkhess is offline
Old 09-18-2013, 01:33 PM
  #107
and the tb03 could get lower with an 88 spur i think 3.8 range i know 4.0 for a fact
rkhess is offline
Old 09-18-2013, 02:31 PM
  #108
Hebiki's Avatar
Trader Rating: 26 (100%+)
ive gotten a TB-03 down to 3.6.
Hebiki is offline
Old 09-18-2013, 02:41 PM
  #109
CraigMBA's Avatar
Trader Rating: 22 (100%+)
I've gotten a TB-03 down to 3.2 (72/55) and I know I can get as big as a 59 in there.
CraigMBA is offline
Old 09-18-2013, 05:29 PM
  #110
Airflow's Avatar
Got mine. But haven't started the build.
Airflow is offline
Old 09-18-2013, 05:47 PM
  #111
speedy_w_beans's Avatar
Got mine as well! I measured the inside of the T5/T7 parts, and as long your pinion is smaller than 18.3 mm diameter it will fit between the motor mounting screws.
speedy_w_beans is offline
Old 09-18-2013, 05:54 PM
  #112
Travis S's Avatar
Trader Rating: 46 (100%+)
Eagerly awaiting to hear if the TB04 gear diff will fit in the TB03! Someone has to have both cars and be able to test this out for me!
Travis S is offline
Old 09-18-2013, 06:13 PM
  #113
Both the TB04 and TB03 use the same "A" parts tree, 51351, which includes the gearboxes. This means TB04 gear diffs and TB03 ball diffs should be interchangeable. I haven't built my TB04 gear diff yet and tried it in a TB03, but in theory since the parts trees are the same it should fit with zero problems. I do think you'll want to match the pinion and ring gears, not mix a TB03 pinion with a TB04 ring, since they come as a set in 51547.
Old 09-18-2013, 06:18 PM
  #114
Airflow's Avatar
What I like about the gear diff is its now ball bearing supported at the outdrives and the big bevel gear is separately mounted by additional 4 screws.
I wonder if the transponder area underneath will affect the airflow since it will catch some air. Would be better if Tamiya included a cover for it. My brother thinks it could be used for hiding the RX or array of capacitors. Also the suspension block no longer includes the option to use 2.5degree toe in at the rear. I think it's just for 3degree set up. Also included it the Moly grease for the suspension balls, cvds and dogbones.
Still be sourcing additional hop ups before I start the build.
Airflow is offline
Old 09-18-2013, 06:25 PM
  #115
Core Creations's Avatar
Trader Rating: 108 (100%+)
Where are they in stock?
Core Creations is offline
Old 09-18-2013, 06:30 PM
  #116
For hop ups I'm thinking about the front one way as well as the steel diff gears and metal cross shafts... Other than that, the car should be pretty good out of the box.
Old 09-18-2013, 06:39 PM
  #117
Right now I don't see them in stock anywhere...
RCMart sold out
Speedtech has it listed as pre-order
Tower has it listed as pre-order
Stellamodels doesn't have it listed
TQ doesn't have it listed
Horizon doesn't have it listed
They just showed this model at the Tokyo Hobby Show and it was just released...
Old 09-18-2013, 06:41 PM
  #118
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
speedy beans, will you do a documented picture build?
Dan is offline
Old 09-18-2013, 06:53 PM
  #119
Sure, if several people want to see it go together I'll start posting pictures of the build step-by-step. This build might span a week as I can only afford an hour or two per night to work on it...
Old 09-18-2013, 07:11 PM
  #120
R/C Tech Elite Member
Big Midget's Avatar
Trader Rating: 101 (100%+)
I'd like to see the build
Big Midget is offline
