Like Tree11Likes
Tamiya TB04 Pro
Old 09-01-2014, 12:02 PM
  #841
Originally Posted by Wade....
I have been having issues during my build regarding the transmission output shaft binding and the top cases not sitting right on my TB04pro II build. Basically the same ones already mentioned earlier in this thread by others.
It seems all of it is due to poor top case plastics not fitting right on the thinner of the two 10mm bearings on the output shafts. A touch of a grind with my dremel and everything is dare I say... 'free'. I hardly removed any material, but it made a world of difference.
I wouldn't have done that. I installed .1 millimeter shims between every hole on all the covers to the car. That freed everything up
Juan Aveytia is offline
Old 09-02-2014, 12:15 AM
  #842
Originally Posted by 9and3
I'm guessing you're running without a servo-saver. With a fender'd body, I don't understand with benefits of using one, but I'm new road cars. Is skipping the servo-saver standard or recommended practice? Thanks.
It is personal preference, track and quality of servo dependent I would say. If you have a plastic gear servo, I would use a saver. Seems like people have been discussing it for over a decade on rctech (and I have not been around RC that long )
I have both direct and servo saver in my cars. My m05 has servo saver because I crash that... a lot...
In my TB04 and TA06 I use direct, I run almost exclusively at Tamiya America Raceway which I find very forgiving. I haven't broken any servos yet (I have mostly Futaba S9551s). It feels "snappier" to me. More direct
Hopefully someone smarter than me will chime in.
torg is offline
Old 09-02-2014, 05:48 PM
  #843
EDWARD2003's Avatar
Has anyone had any issues with the gear differentials not being smooth? I've built one so far and it the differential is not smooth whatsoever. I've removed 0.1 mm shims on both sides and removed any flashing. The only time the differential operates smoothly, i.e notchy gear feeling is when I back the screws off a little.
When I do this, this causes the oil to leak. So obviously I'm not doing something right.
EDWARD2003 is offline
Old 09-02-2014, 05:54 PM
  #844
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Build it to kit specs, run a pack through it, recheck.
Frankly that good advice for all the gear train.
CraigMBA is offline
Old 09-02-2014, 06:23 PM
  #845
Raman's Avatar
Trader Rating: 94 (100%+)
+1 I built my Pro II as per manual. No issues after 6 heats of racing. In fact drive line has become much smoother
Raman is offline
Old 09-05-2014, 06:56 PM
  #846
TB03Racer09's Avatar
Just purchased some Tamiya brand, aluminium suspension blocks (1XA and ID) for the rear of my TB04 as well as some 3racing M3 1mm thickness aluminium shims to the remove slop in the rear suspension arms. The front seems quiet slop free so I'm not going to upgrade those just yet.
TB03Racer09 is offline
Old 09-06-2014, 05:02 AM
  #847
Usually to remove slop in the suspension. (1)mm is to much. (.1) is what you normally need
Old 09-06-2014, 04:21 PM
  #848
I already have a pack of 0.1, 0.2 and 0.3mm M3 shims handly. I also wanted the thick shims on the suspension pin to be aluminium as well because I found that the plastic ones can wear down a little.
Old 09-06-2014, 10:18 PM
  #849
Solved my steering throw issue. Turned out that the link between the servo horn and bell crank was too short. I made it 32.5mm and now have all the steering I would ever need and on top of that, the steering angle is equal left and right.
Old 09-30-2014, 12:20 PM
  #850
vivo quevas's Avatar
Trader Rating: 19 (100%+)
How much lighter are the carbon reinforced chassis and the other CF parts are over stock parts?
vivo quevas is offline
Old 09-30-2014, 01:17 PM
  #851
Wade....'s Avatar
They are barely lighter. Rear standard arm weighs 8.0g. Rear reinforced arm weighs 7.8g.
So... about 2.5% lighter. My guess is you might save ten grams if you change all the regular plastics to carbon.
Wade.... is offline
Old 09-30-2014, 01:24 PM
  #852
Wade....'s Avatar
Default Happy to report!
Now that my TB04 Pro2 is built the chassis no longer tweaked, but nice and flat. So don't let a warped chassis bother you, it will flatten out once built.
Wade.... is offline
Old 09-30-2014, 01:38 PM
  #853
maxepower's Avatar
Talking Smooth as silk!
You running the metal or the plastic gears. I suggest using the metal. They hold up forever and much smoother.
Just my 2$
maxepower is offline
Old 09-30-2014, 01:45 PM
  #854
9and3's Avatar
Wade... just so I understand, you omitted/eliminated the chassis that came with the Pro II and substituted it with the optional (Tamiya #54596) Carbon Fiber-Reinforced Lower Deck, right?
I was wondering if that chassis was noticeable stiffer or if it was just bling. Thanks for sharing.
9and3 is offline
Old 09-30-2014, 02:13 PM
  #855
Wade....'s Avatar
No, I am running the chassis that came with my Pro2. Not sure, but I think it is not the reinforced version but the standard...? I could be wrong here.
But no doubt the reinforced chassis will stiffen the car up (assuming the kit one is standard chassis). The reinforced parts are much harder. I put all reinforced arms/hub/knuckles on mine because I couldn't source the non reinforced parts easily.
Wade.... is offline
