F201
#2086
Ray
Im not sure if it has been posted anywhere yet but if oyu have seen it try my TCS setup from the worlds, i will try and write it down the car is still in same condition as the last final
I plan on getting the car mounted in a cabinet, i will post pics when it is done.
Main thing that i found with the car is that toe and camber make more changes than everything else, i always liked a fair bit of toe out in front, and very minimal toe-in on the rear. Camber set around 2-3 degrees, dont be scared of going up higher it really locks the car in. Running a stock motor the high speed gearing shoudl be fine on a medium size track, on a small one try the std ratio, also try to get oyur hands on a tamiya stock these are 23 turn, can pull a taller gear ratio and dont get affected by the heat as much. Also when running a stocker i found to use some idle up, it helps minimise the rear end coming around off power. oh and dont be scared to tighten the diffs up this will help keep the car planted.
Once you get it dialled in they are an extremely pleasurable car to drive. Good luck.
#2087
Originally posted by Besercoe
Ray
Ray
Ray
#2089
Anyone looking to sell any type A's or B's for f201. Looking for brand new only.
[email protected]
Kevin
[email protected]
Kevin
#2090
[email protected]
Kevin
[email protected]
Kevin
We got tires
Tamiya F201 tires and rims
Steve Wang
#2091
hello, i am slightly interested in getting one of these being a big F1 fan. and my local track has a class for them too. i have a few questions: is the car cometitive out of the box (besides tires, springs, shock oils, electronics...), is there any way to put a side-by-side battery in the car instead of a stick pack, and does it have friction shocks or oil filled? i have a TL01 and i dont want anothere car like that. is this a fast, competitve car? what kind of hopups do you guys suggest to get.
thanks guys
marshalv.
thanks guys
marshalv.
#2092
It has oil shocks. Get the tires right away. Also the front end and gearboxes are somewhat fragile, so get the heavy duty lower arms. It is designed for sticks packs (though if you do some careful grinding, I have heard you can use side by side packs..either that or get the 3Racing chassis). The other thing to get right away are the upgraded (lightweight) diffs, the stock ones can be pretty weak. If you can spring for it, get the adjustable alloy motor mount too.
#2093
thanks guys
marshalv.
thanks guys
marshalv.
Kit
Type A tires for most tracks.
Lightweight diffs (the std one have a habit of snapping the diff screw)
shocks are plastic but oil filled.
only way ot put side by side cells is with one of the graphite chassis conversion kits
and if you are racing against other F201's then yes it is competitive. Best of all they are a ball to drive.
#2094
Things required.
Kit
Things required.
Kit
#2095
how much will of of this cost? the car, the diffs, the chassis, the tires, the arms, the adjustable motor mount...
#2096
Things required.
Kit
Things required.
Kit
#2098
Originally posted by Neil Rabara
What's up champ! Looks like we are gearing up for another year of TCS. Might be the last for US for F201. How's the hot weather treating you?
i have been having fun running the 415, it is such a pretty car. lol but it also handles extremely well, it just seems to make the track feel wider, it just goes wherever you want it to. I ordered a set of Acer ceramics for it, as the kit wheel bearings are failing already, im not a fan of those little 950's.
Re TCS in Australia, not too sure whats happening yet, but you can bet i will be in there giving it my all, there is more fun to be had in japan. Im eligible to run in the GT1 class this year so continued practice with the 415 is on order. There are rumours that TCS will be in estern Australia this year, which is on the other side of the country, so will have to get together the annual leave and the cash.
Disapointing thing is though i have not even had a "well done" reply from the local Tamiya importer.
re the weather we have had more than our fair share of near 40 degree days so racing has been interesting, we have seen more than a few motors and speedies go poof in the heat.
#2099
Hi man things are going well, the F201 is sitting pretty on the shelf, it will be getting mounted in a cabinet as soon as i can spare the cash.
#2100
Re: carpet setup
Originally posted by minidriver
Neil: please check your PM.
