F201
#2074
stick battery care
Hey guys,
Gotta question that may have been addressed receintly, but havn't seen.. What have you found out to be the best way to cycle, discharge and store your custom stik packs. IS anyone dead shorting them and storing them that way? The peak voltage seams to climb each charge (not good) and the resistance increases (also not good) and the run time seams to suffer also. I'm using a Comp ElectronicsTurbo 35 and charging at 6 amps..any info or tips
#2076
Originally posted by over gear
where did you get that motor fan?? looks good!
I have on myself.....
#2077
I found it:
cooling fan
Question is does it fit on the stock chassis and stock motor guard?
It looks really squeezed in on the 3R chassis.
cooling fan
#2078
It's actually a Much More Racing Motor Fan. If you have a look at Mr Vercoe's car (F1 World Champion) on Tamiya's website, he had a piece of plastic or something like that screwed in on top of the motor guard with overhang, and he had 2 motor fans taped onto the plastic part. Now that was obviously with the std chassis so yeh, its possible.
#2079
#2080
yes thats it, i got two of these, made up a mount using material from an old blue fibreglass 12th scale t-bar, i made the mount a few layers thick so that the fans were directing their airflow directly to the motor, it was all held together by superglue, and mounted to the alloy chassis brace by the 2 screw holes. I wired the power through to the pos and neg battery wires of the speedo, this made the little buggers work hard but it moved a lot of air. I will try and find a pic and learn how to post them
#2081
F1 decals - what's the update
Hey Mark,
Was there an updated info on the decals that you were planning to produce? I was away and without access to internet for about a month and did seem to find anything after I came back.
Let me know thanks,
roy
Let me know thanks,
roy
#2082
handling and gear ratio
Hey all,
I finally got to run my F201 today. I ran n a med grip Carpet track on type A's. Just three runs, but chnaged springs and ride heights. I think the bump steer leads to some odd handling, but it was cool to see how the tires need to warm-up and then hear them squeel.
ANyways-my first question is-how are you gus adjusting ride height inittially.? With kit springs in front-car was about 5mm. I put the stiff olives up front and front ride height jumped to 7mm!! I lowered it by adjusting the length of the pushrod. Is this right? I dont see any other way as I already had no clips. Ditto on the back. I started with soft springs and the thick and thin clip-then went to medium (gold) sorings and took the thick clip out.
Next-I ran the kit gearing with a ROAR STock. I had decent top speed, but very little bottom end. Motor was whicked hot too. Seeing as how tire size and pinion are fixed-what can I do about being overgeared?
Thanks,
Ray
Thanks,
Ray
#2083
Wow, nice. First I've seen or heard of this... I had seen this suspension type in off-road glow vehicles and knew it was the same thing as in real F-1 cars... for the rest of the chassis, I'd have to agree with the author of that news post way up on the first page. I'd rather have a 1-1/2 or 2-deck CF chassis for more flexibility in placing components. Looks like the shaft is pretty well-protected, but doesn't come out real easily if you want to switch between 4WD and RWD.
...Real rollbar! no more seriously crushing the shell... As if I've ever flipped my 103 without trying.
#2084
Re: handling and gear ratio
Thanks,
Ray
Thanks,
Ray
#2085
Thanks-it was fun to drive Neil. if you got even a tire out of the groove-car came around. Also-driving style is critical-as I can already feel a fine line between push and loose on this car. IN other words-to make car steer-it feels like the cars very loose off power. Running th car n carpet at 4mm seemed good too.
No problem on droop-I am controlling that with the o-rings in the shocks. 3-front 2-rear, but I think thats gonna chnage.
