Like Tree34Likes
Schumacher Mi5
Old 09-05-2013, 03:25 PM
  #1321
haywood's Avatar
Trader Rating: 49 (100%+)
Originally Posted by scott_g
According to Martin Hofer's build blog (for the ultimate in performance), it's 3mm approx. See here: http://hofaaa.wordpress.com/2013/06/...ortance-of-5p/
Lots of good tips there.
Thanks! That's what I thought.
haywood is offline
Old 09-05-2013, 09:00 PM
  #1322
R/C Tech Elite Member
DiscountRCStore's Avatar
Originally Posted by jdm19turn
if you could send me a pm once you got them instock and I'll place a order
You bet.. no problem at all. .
..p
DiscountRCStore is offline
Old 09-07-2013, 11:54 AM
  #1323
reg
How are the shocks holding up with regards to leaking?
reg is offline
Old 09-07-2013, 12:37 PM
  #1324
snuvet75's Avatar
Trader Rating: 16 (94%+)
Originally Posted by Dusttt
Actually the car is great just a case of too many cars and not enough time
Same here LOL It's been getting ridiculous for me. Thinking of getting rid of everything but one.
snuvet75 is offline
Old 09-09-2013, 04:43 PM
  #1325
Trader Rating: 16 (100%+)
Default SCHUMACHER MI5 PROBLEM
having A PROBLEM with changing my mi5 from 17.5 to vta. I cant get the right ride height. The shock towers are not tall enough. Does anyone have a answer to my problem.
Thank you
jtsbell is offline
Old 09-09-2013, 05:16 PM
  #1326
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Thank you
make sure that the grup screws is reset ..
OVA is offline
Old 09-09-2013, 05:18 PM
  #1327
Trader Rating: 38 (100%+)
I finally signed up for IIC last night, one more Mi5 added to 17.5 TC and Spec GT.
linkless is offline
Old 09-10-2013, 07:19 AM
  #1328
For those who are running mid-motor setups. What changes did you find you needed to make to the cars overall setup if any? I'm currently running Hofer's std setup on asphalt and I'm thinking of running the Mi5s in mid-motor at IIC.
cgroves is offline
Old 09-10-2013, 08:17 AM
  #1329
+ 1, I will also be at the IIC, I have the same question..
gdcopbdcop is offline
Old 09-10-2013, 09:45 AM
  #1330
The Teacher's Avatar
Trader Rating: 62 (100%+)
I'm going to the IIC as well but have yet to find a good setup for the MI5 on carpet. My car just seems to flex way to much when the bite comes up. Do any of you have a good setup for carpet...???...or are most of you using Hofer's setup?
The Teacher is offline
Old 09-10-2013, 09:58 AM
  #1331
olhipster1's Avatar
Trader Rating: 102 (100%+)
i think for high traction carpet the mid motor option may provide results.
anyone running this? feedback please.
did you try the additional standoff on top deck?
I plan on getting the mid-motor setup soon.
olhipster1 is offline
Old 09-10-2013, 10:23 AM
  #1332
Is anyone using the cut arms on carpet? Or are they leaving the arms alone?
so many questions, and I don't have a carpet track to practice on before the IIC!
Old 09-10-2013, 10:28 AM
  #1333
olhipster1's Avatar
i would think cutting the arm would give more flex overall...may not help on high traction.
Old 09-10-2013, 11:38 AM
  #1334
olhipster1, yep tried the additional top deck brace. It helped some but not nearly enough. Only thing I have not tried was the short links...think this will free the car up some in the corners but I still think the chassis will flex creating too much grip.
Old 09-10-2013, 12:57 PM
  #1335
I have run both rear and mid on carpet, and am sticking with mid, with the following settings.
Note we run 13.5 boosted on med grip carpet grip comes up during the night.
400cst oil all round,
green springs all round,
As little rebound as possible,
5.5mm ride f/b
0.5 toe out front,
3.0 out rear,
NO washers under wishbones,
2mm under inboard ball joint (on camber plate)
1mm under outboard (on hubs) front and back (although back already has 1mm)
-2 degrees camber all round,
2000cst diff oil,
front double jointed drive shafts (optional)
Montech Nazda 2 low grip and 3 later heats
droop 5 front and 4 rear (on the hinge pin that the hub connects to the wishbone)
we use jb28 aat our local club or 32's at another club which has gts etc so high grip.
car is great like this and carries a lot of corner speed.
I run a shorty lipo and 2 x 10g weights at the rear. when the grip is high I change to red springs just on rear which stops the weight transfer to quick and grip roll.
nmsraider is offline
