Tamiya TT02 Thread
#1203
hello!
can someone give me a starting Setup for carpet and outdoor? TT02S
at the Weekend am struggling with my car at the Tamiya Eurocup (black ETS carpet).
At the begining everything seams fine but then the Desaster started.
thank you!
thank you!
#1204
I've only run on black ETS carpet once with my TypeS but spec was kit shock positions, TRF (42102) shocks with 3 hole pistons and 40wt front and rear, AW grease in front diff, blue (hard) front springs, yellow (medium) rear, 3 degree rear toe in, droop stops fitted but no droop screws in the arms, no toe-out on the front (just parallel) and a glued up servo arm. Car was dialled every run. Couldn't fault it, just used less tyre sauce as the grip came up. When did yours go bad? As the carpet rubbered in?
#1205
#1206
What is it doing that you don't like? What would you like it to do that it doesn't?
#1208
in the finals it began to struggle.
maybe I also set the front to low.
I´m so frustrated that at that time, that I think in the wrong way.
I also sauced the fronts only half.
go from blue/blue spring to blue fr / yellow rr but no Change.
I had 1,5° toe out front each side.
spool front, aw grease (Little) rear.
drop screw front screwed out to lower front (I think that could be the reason)
#1210
I've just ordered a TT-02R to get back into a bit of local stock class/VTA style racing after about 15 years away. It all started with a TA-01 so i'm looking forward to building this type of kit again.
Just wanted to say the reviews and useful info on your blog has been a great help Oatmix
#1211
1386Likes
