Tamiya TT02 Thread
#1217
Mark
#1221
Depending on the class, you will probably need to change gearing to get the final drive ratio around 4 or lower. Mine is set up for USGT and I run the optional gear adapter that accepts other spurs and also use the Yeah Racing motor mount.
Fan on the motor is usually a good thing, especially when you are running really tall gears.
#1222
#1223
Hi All,
I have not run Silver Can in ages. I am setting up a TT-02 to get my 5 year old son racing. I'll start with the stock gearing, but if he manages to not crash much, can anyone recommend a gear ratio for the torque tuned motor? Do I just drop it all the way down, 5.74?
Thanks,
Jose
Thanks,
Jose
#1224
With the standard motor mount you can get 5.74 using the high speed gear set, 29T pinion and 64T spur
#1225
The yeah racing motor mount is the only non Tamiya part I have on any of my Tamiya cars
The Tamiya mount has fixed holes the yeah is adjustable. That's the benefit. Disadvantage is it's not legal for TCS races
#1226
I JUST SCORED!
I've been thinking of making the updates to my standard TT02 to convert it to a Type S (carbon uprights, suspension mount kit, new a-arms, castors and bearing carriers, etc). All told I was looking at close to 150 bucks. I was poking around Ebay and found a store front that looks like they part out Tamiya kits. I was able to snag the entire B bag with almost all the parts I need for 30 bucks shipped from UK to Seattle. ALl I need is the a-arms and rear bearing carriers now. What went from another 150 bucks on a 100 dollar car is now about 65!
#1229
I JUST SCORED!
#1230
1387Likes
