Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 05-19-2015 | 04:57 PM
  #706
SagadSetup's Avatar
Originally Posted by rough512
I did my DIY conversion to S. It is not complete though. I'm definitely buying that drift S-type when it reaches the LHS.
I am definitely getting at TT02 S. I saw somewhere that there will be a provision for droop screws.
SagadSetup is offline
Old 05-19-2015 | 06:24 PM
  #707
Just to continue with conversion discussions. Those of you with Type-S know this but those that don't have the car, you can see the 'special' pieces needed for the conversion. There are not that many as seen in this picture. The complexity is that you then need the complete suspension and drives from a 417, 418, 419, TB04 Pro or similar.
ic-racer is offline
Old 05-19-2015 | 06:34 PM
  #708
SagadSetup's Avatar
I guess it would be more cost effective to buy the Type S kit itself.
Old 05-19-2015 | 07:02 PM
  #709
rough512's Avatar
Plus the shock towers and the suspension spacers/mounts are not really available separately.
rough512 is offline
Old 05-19-2015 | 07:20 PM
  #710
SagadSetup's Avatar
Thanks for the info.
Old 05-20-2015 | 02:46 AM
  #711
Yes, you will be able to buy the parts to convert it. Here is are the part numbers, not all of these parts are available yet, but will be very soon (June)
TT-02 to type-S conversion parts
Tamiya 54634 - Suspension metal parts set
Tamiya 54632 Front carbon Type S shock tower
Tamiya 54633 Rear Carbon Type S shock tower
and also to get droop settings sorted you can get
Tamiya 54638 - Steel rebound stopper (You will need two of these as they only come as a pair). You can only fit the rebound stopper on this steel suspension set, not on the kit set (I have been told, but cannot confirm). so if you have the S you can buy the seperate parts 54636, and 54637 which replace the kit part and are cheaper than buying the full set.
Qatmix is offline
Old 05-20-2015 | 04:27 AM
  #712
SagadSetup's Avatar
The TT02 is turning out to be quite a competitive entry level chassis. Almost all of the features I am looking for is there. Plus I can mount those lovely Tamiya bodies I want without making a mistake in doing so (I am bad at it). All I have to do is follow the dimples! Yes!
Old 05-20-2015 | 05:42 AM
  #713
MD's Avatar
MD
The weakness of the car are the steering uprights. I would definitely by aluminum after front uprights.
MD is offline
Old 05-20-2015 | 06:00 AM
  #714
Yep, but if you move over to Type-S that is resolved as the TRF416 uprights are fine.
You could also look at adding TA04 suspension arms on the S as they are really tough.
Qatmix is offline
Old 05-20-2015 | 09:44 AM
  #715
SagadSetup's Avatar
Oh my... I just gave away all of my TA05 V1 arms, uprights, and knuckles as part of my deal.
But won't that restrict the wheelbase adjustment as well?
Old 05-20-2015 | 10:08 AM
  #716
was wondering where i could get a cheap camber mod for the front, i tried to add camber but the rob that connects the diff to the wheel was to short or the front lower arm was limiting its movement?
could i have some links to some kits etc and advice please? UK ONLY PARTS
connormorrison9 is offline
Old 05-20-2015 | 10:15 AM
  #717
I had a simple guide. you can actually try to use some Metal PC spacers to do the same thing as the machined parts
http://www.thercracer.com/2014/11/ta...er-caster.html
Qatmix is offline
Old 05-20-2015 | 10:45 AM
  #718
[QUOTE=Qatmix;14017856]I had a simple guide. you can actually try to use some Metal PC spacers to do the same thing as the machined parts
this is what iv found and tried but it didnt work for mine as the lower arm stops it from moving atall along with the dog bone?
Old 05-20-2015 | 06:44 PM
  #719
rough512's Avatar
Thanks for this info Qatmix. Now if only our LHS brings these in. I already have the carbon unit for the regular TT02. It works just fine with the transplanted TRF suspension I'm using.
rough512 is offline
Old 05-21-2015 | 03:38 AM
  #720
[QUOTE=connormorrison9;14017906]
Do you have a picture? I've done this on quite a few TT02s for friends and not had an issue
Qatmix is offline
