Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 09-19-2025 | 08:39 AM
  #4096
This is my SRX.
This is my SRX.
Qatmix and chjosi like this.
RaceDoc is offline
Old 09-19-2025 | 08:40 AM
  #4097
... and here is the setup sheet for this test and shootout.
Stephtruc, G-rem and chjosi like this.
RaceDoc is offline
Old 09-26-2025 | 06:40 AM
  #4098
I hope that I can give it the next try at the first October weekend.
RaceDoc is offline
Old 09-29-2025 | 11:05 PM
  #4099
G-rem's Avatar
Hi there,
here is my setup for a TT02 SRX fully hopped-up for a large outdoor asphalt flowing track : https://site.petitrc.com/reglages/ta...avez_20250921/
Feel free to reach if any question
G-rem
RaceDoc likes this.
G-rem is offline
Old 10-02-2025 | 09:39 AM
  #4100
Rickz's Avatar
Guys got a question on my tt02R I have been running it a lot for tcs and now that tcs is over we have a super gt class that I am running it in, we run the the hobbywing just stock 21.5 setups in them blickey and fixed timing. we are required to run the ride 2426 tires (so not sure what shore rating is). I have some upgrades on the car, Tamiya universals on front and rear, Trf shocks (30mm length to get ride height at 5.5mm), also has carbon fiber shock towers, and carbon driveshaft.
My setup now is 5.5mm ride height, 40wt oil in shocks front and rear, yellow springs on all 4 corners, 2.5 degrees of toe in rear, and 1 degree of toe out up front, 1 degree of camber all the way around, 500,000 in front diff and tamiya AW in rear diff. Gearing is 64p 74t spur, 55t pinion
The problem I am having is car is hopping in rear on corner entry and not sure what I should do to fix it. I know with my mini z experience when they hop in the rear you can usually fix by softening up the rear, not sure if it will do the same on the tt02. Any help would be much appreciated, and please just let me know if you need any mor info on my setup.
Thanks Rick
Rickz is offline
Old 10-02-2025 | 10:40 AM
  #4101
From: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
lighter oil and lower ride height to start? I use front spool and 3k diff oil out back.
do you have a shock limiting spacer inside the shocks?
lagcisco is online now
Old 10-02-2025 | 03:06 PM
  #4102
R/C Tech Elite Member
more camber?
try 2* ..... youre probably bouncing off the side wall tire edge of the harder compound.
Robbob is offline
Old 11-19-2025 | 12:38 PM
  #4103
wallstreet's Avatar
what are the newest shock available for TT02 SRX please provide a part number as well. Thank You
wallstreet is offline
Old 11-19-2025 | 12:40 PM
  #4104
I use the super short big bores but you’ll also need SSBB towers as well, Psm and mttr both make them
G-rem likes this.
Old 11-19-2025 | 01:06 PM
  #4105
wallstreet's Avatar
what would happen if i didn't get the shock towers...does Tamiya make the correct towers?
Old 11-19-2025 | 01:20 PM
  #4106
you can flip the stock towers I believe but you will lose the body mounts. Use other mounts
G-rem likes this.
Old 11-19-2025 | 06:50 PM
  #4107
disaster999's Avatar
Regional Moderator
Im using SSBB shocks with the stock SRX shock towers and they fit fine. Granted I have to change the ball cups to the longer one and didnt thread it all the way in to create the length needed. I used the spring spacers that came with the kit as well as the SSBB springs are too short and you will run out of thread backing out the preload trying to get the correct ride height.
disaster999 is offline
Old 11-19-2025 | 07:43 PM
  #4108
try these tips, flip the towers
https://www.thercracer.com/2020/03/u...02-type-s.html
G-rem likes this.
Old 11-19-2025 | 07:55 PM
  #4109
Regional Moderator
Originally Posted by lagcisco
it might work running it upside down, but that leaves little to no room for tuning options. You are pretty much locked into 1 or 2 shock position before needing to lengthen the shock to get the correct travel
G-rem likes this.
Old 11-25-2025 | 02:47 PM
  #4110
bigl's Avatar
Hi I’m looking to build a car for gt pro spec/Porsche cup and wanted to see if anyone knows if I can use the front dcj and rear uni’s from the srx kit with the R arms and hub?
bigl is offline
