Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 08-25-2024 | 04:55 PM
  #3916
Originally Posted by LordSchnert
A slightly different perspective.. it really is only a problem for the stock TT02.. Type R, S, RR, SRX all don't use the plastic dog bones that like to pop out. That said, we run box stock TT02 not so much as a beginner class but as a low cost 'rubbing is racing' class.. beginners are of course welcome.. but it is sometimes more demolition derby than 'serious racing'.. everyone running a track knows.. it's all about the numbers.. you need to get people through that door.. and these days the basher community is much larger than the racer community.. folks are having a great time.. and the hobby shop sells a lot parts.. for us the main reason for allowing and selling CVDs is so we don't have people out on the track all the time looking for missing dog bones and drive cups..
That is a rite of passage for any beginner, searching for a lost dog bone, and having some eagle eye veteran spot it across the track from the pits.
SteveM, Revolter22 and River19 like this.
Jrxpro is offline
Old 08-26-2024 | 05:50 PM
  #3917
JoeSneam's Avatar
Questions?? what is wrong with my car?!
Help! I have a Tamiya tt02 drift conversion (4wd) and it will only drift to one side, it turns both ways evenly but won't drift on one side but still drifts perfectly on the other.
JoeSneam is offline
Old 08-27-2024 | 11:26 AM
  #3918
Sorcerer001's Avatar
Have you done all the basic troubleshooting? Suspension setup is the same side to side? Drivetrain is free, no binding, particularly at one corner? Radio trim and end points are set correctly?
Sorcerer001 is offline
Old 08-27-2024 | 12:03 PM
  #3919
JoeSneam's Avatar
Yes, this is a new problem, it was functioning fine earlier this week.
JoeSneam is offline
Old 08-30-2024 | 04:20 AM
  #3920
wallstreet's Avatar
I have a tt02 and i don't understand why a bitty design 190mm porsche boy is to wide for the car?? Is this normal for the tt02 to only have tamiya bodies use on this chassis
wallstreet is offline
Old 08-30-2024 | 06:15 AM
  #3921
simple's Avatar
It all depends on the parts you used while building the car. There are steps specified in the instructions and components that serve to widen the track depending on the body to be used.
There are also longer outdrive axles and hex’s available to move the wheels out to full width.
simple is offline
Old 08-30-2024 | 06:19 AM
  #3922
wallstreet's Avatar
thanks
I’ll check it out
Old 08-30-2024 | 06:31 AM
  #3923
Which smaller spur gears fit the TT02's 4 hole bolt pattern? Looking for low 70T spurs to get USGT and VTA gearing.
chjosi is offline
Old 08-30-2024 | 06:39 AM
  #3924
wallstreet's Avatar
Ive been looking at the manual it looks like the disc brakes is a plastic piece that makes the car wider. Seems to be the only part. is that it or am i missing something else?
simple likes this.
Old 08-30-2024 | 07:20 AM
  #3925
angrymelon's Avatar
The wider plastic hex/disc when used with the stock axles, you'll find you dont have enough thread to mount your wheels. Tamiya sells a TT02 parts tree that includes the wider axles. However, only one is included per pack. I had a friend confirm that the TT01 axles work, and they sell a pack that includes two of the longer axles.
simple likes this.
angrymelon is offline
Old 08-30-2024 | 10:04 AM
  #3926
simple's Avatar
Yes, this is the stock solution.
simple is offline
Old 08-30-2024 | 10:17 AM
  #3927
simple's Avatar
The other way, that I have on a few of my cars is some TG-10 axles, with wide hex hubs like these.
lagcisco likes this.
simple is offline
Old 08-30-2024 | 11:04 AM
  #3928
skater-deez1's Avatar
I just milled down the like 15mm hexes that come with the car, they hold the pin tight so no issues when you take the wheels off anymore.
skater-deez1 is offline
Old 08-31-2024 | 05:43 PM
  #3929
honda93's Avatar
Questions??
Found my issue. Thanks.
honda93 is offline
Old 09-01-2024 | 09:01 PM
  #3930
Samich's Avatar
Posting this in case the info helps someone.
There are two "versions" of the #54558 Tamiya TT-02 Aluminum Motor Mount.
The version of the #58558 Aluminum Motor Mount that is available as a separate hop up part has 5 attachment positions per side labeled for pinions 16T-25T.
The version of the #58558 Aluminum Motor Mount that comes included with the TT-02R and TT-02RR kits also has 5 attachment positions per side, but its labeled for pinions 18T-27T when using the included high speed gear set 68T spur. It’s also machined slightly differently.
The version of the mount that comes with the R/RR kits isn’t available separately (as far as I can tell). I just happened to notice the difference when I was swapping motors between my regular TT-02 and my TT-02R (built without the highspeed gear set since its not allowed in our club’s TT-02 class).
Not sure why Tamiya chose to use the same part number, but if you have TT-02R (or RR) kit that you run with the standard 70T spur, make sure you ignore the labels on the mount and pay attention to the A-K labels on the Motor & Gear chart in the manual.
Samich is offline
