Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 09-02-2024 | 01:33 AM
  #3931
Originally Posted by honda93
Found my issue. Thanks.
What was the issue?
YoShImUrA53 is offline
Old 09-06-2024 | 08:36 AM
  #3932
sacmiata's Avatar
Question - I have two kits - one had the MA9 which is this little sheet of paper that goes in between the motor and motor mount. Its labeled the MOTOR PLATE and it seems like its not stocked anywhere. I was going to just make one out of gasket material or just not install it. Tamiya put it in for a reason but I cant figure out why? Does anyone know why and is this really needed? The only purpose I could think of was a thermal break between the hot motor and the plastic motor plate.
sacmiata is offline
Old 09-06-2024 | 09:06 AM
  #3933
Used mostly as a thermal break as you surmised.
sacmiata and Revolter22 like this.
SteveM is offline
Old 09-06-2024 | 06:45 PM
  #3934
Question - Tamiya put it in for a reason but I cant figure out why? Does anyone know why and is this really needed? The only purpose I could think of was a thermal break between the hot motor and the plastic motor plate.
Its both a thermal break, and it prevents dust from making it's way into the gearing.
angrymelon likes this.
Revolter22 is offline
Old 09-07-2024 | 05:58 PM
  #3935
angrymelon's Avatar
My $100 eBay find TT02R that was converted with the Yeah Racing competition suspension and complete with electronics (Futaba TX/RX not pictured). I then modified it to have increased down travel and replaced the front spool with a 2nd sealed diff. This thing has more clearance than a Rally TT02, and obscenely more steering angle. Also has sway bars which is cool! Hope to finish it up and try it out soon.
For those that are curious, the Yeah Racing kit does have replacement suspension parts, they're the same as the Xpress XQ* line of cars.
Yeah Racing TATT-S04 converted for rally.
YoShImUrA53 likes this.
angrymelon is offline
Old 09-21-2024 | 05:19 PM
  #3936
JoeSneam's Avatar
Unhappy Tt02 camber
Recently bought adjustable upper arms for my tt02 drift build, and much to my chagrin when I adjust them so the wheels have negative camber the drive shafts get smooshed, and the wheels become harder to rotate, does anyone know if they make shorter driveshafts for the tt02 or if there is a solution to this problem, thanks.
JoeSneam is offline
Old 09-21-2024 | 07:20 PM
  #3937
Are there any o-rings or spacers in the drive cups that you could take out?
chjosi is offline
Old 09-21-2024 | 10:29 PM
  #3938
jo_er86's Avatar
i reemember having similar issue with a pro spec build.I switched to M07 33mm aluminum drive shafts.
jo_er86 is offline
Old 09-22-2024 | 09:03 AM
  #3939
JoeSneam's Avatar
Thanks, Do you need to buy new drive cups for those? they don't look like they just fit right in.
JoeSneam is offline
Old 09-22-2024 | 09:06 AM
  #3940
JoeSneam's Avatar
The tt02 doesn't have any o rings from stock.
JoeSneam is offline
Old 09-22-2024 | 09:13 AM
  #3941
jo_er86's Avatar
yeah you’re right. It was a TT-02R drive cups. Perhaps adjustable camber links are not meant for the stock?
jo_er86 is offline
Old 09-22-2024 | 09:49 AM
  #3942
JoeSneam's Avatar
So you replaced the stock with tt02r drive cups and then the driveshafts fit?
JoeSneam is offline
Old 09-22-2024 | 01:54 PM
  #3943
JoeSneam's Avatar
Yeah Racing makes M07 33mm driveshafts does anyone know if those fit?
JoeSneam is offline
Old 09-27-2024 | 05:25 PM
  #3944
I spent time turning laps last night at our local indoor carpet track that was setup for 1/10th........was able to get some good consistent laps in but that consistency would melt away into unpredictability after a couple minutes.
The main culprit was one of the through-chassis mounts for the steering rack, and while I have the upgraded aluminum rack one of those mounts would loosen and lead to a ton of slop and wander, add in that I had a C-clip in one of my shocks come off and the piston was floating up and down independent from shaft.
Pulled the whole front end apart today and I think I came up with a permanent fix for metal on metal mounting through the chassis which means LocTite is in play.....so that should solve that crap show. I also finally got off my butt and got some nylon washers that were the right size to eliminate the slop in the front A-arms...... rebuilt it all and this could be the winning combo......
h2e likes this.
River19 is offline
Old 10-20-2024 | 08:59 AM
  #3945
Been working on some floor aero the past couple days. Hopefully this keeps some air out of the body!
skimax is offline
