Tamiya TT02 Thread
#3856
The performance difference with the tt02 and euro trucks comes down to the treaded euro truck tires. On equal tires(usgt spec tires at my club) it's a whole different story. But if they were running the euro truck tires.....good luck those actually work really well.
#3857
I was pretty confident that was the case on equal tires it's the tt02 all day but those tires are probably close to half a second quicker. I spent 3 seasons in production Tamiya, I could easily write a book on them....
#3859
No doubt.
Good drivers with those stock Euro Truck tires prepared correctly are running high 11 to mid 12 second laps and I am mid 12 seconds to 13.8 secs on average if I keep my crap together. The bulk of the difference is their driving skill but the rest is the killer tire setup for carpet while I am on Power Hobby spec tires.......
#3860
Input needed. So we started a TT-02,01 class a few months ago. Our goal was for someone to come in, buy a kit & build with minimal expense & needed parts. We stocked all sorts of TT-02's & 01e. We allowed bearings/shocks/front cv's. We use Gravity USGT tires as spec. Everything was going smooth until a couple people burned up pinions and also noted that pinions & ratios are different kit to kit. Seems rally vs gt car.
So now the question. Do we allow open gearing & let it sort it self out? I picked up1 sec/lap with my 01 going from the kit 19t to a 22t.
I did make a huge graph showing fdr on both 02 & 01 with Tamiya spur & different pinion sizes. Seems both 02 & 01 are 2.6fd
Edit, if we allow open gearing, what is the best method to do so? Everyone already has 48p & 64p in their tool boxes but these are mod .6. Do we stock the Tamiya spur gears & pinions? Is there a way to switch to 64p? Or 48p?
#3861
Maybe the "most fair" way is to allow people to upgrade gearing and necessary parts to match the top tub-chassis spec and everything in between. The other idea would be to design the course so there is more of a pro/con to gearing decisions. If you have a long straight away then of course the "high speed gear sets" will be quicker apples to apples.
Just my $0.02
#3862
#3863
And up here in the Northeast, most tracks that run Production allow: Bearings, servo saver (or horn), Front CV's (Tamiya Part #53792 used with #54477 on TT-02, or used with #53790 on TT-01e), Tamiya Diff putty or any grease in front diff, aluminum center shaft/joints and aluminum wheel hexes. Body must be a Tamiya body. Tires are USGT belted gray for carpet and regular USGT tires on asphalt.
#3864
Those items cover the reliability challenges with the TTs.....the servo saver, dog bones and plastic hexes......add some bearings and go racing....that setup is reliable.
#3866
Last night carpet race was a mix of highs and lows. First qualifier was great, finished 3rd where I should have based on driver/car abilities etc. Second qualifier was going well until the car started handling oddly, right rear tire had come unglued so I limped through the last couple mins. For the Main I elected to swap to 4 new tires after running a few practice laps to break them in, the rear was a little loose so I went with some sauce and that was a mistake. I turned into a traction rolling nightmare.......oh well.
TT-02 racing is just a goofy amount of fun all things considering.
#3867
Now I always glue my sidewalls, and even more so that I started running on carpet.
#3868
I had the same issue when we ran asphalt with sugar on it, at our local track. The veterans kept saying glue the sidewalls of the front tires. But I kept denying it and kept traction rolling. Finally I was frustrated enough to give it a shot and instead of trying to slow down more for corners I was able to dive in REALLY deep after I glued my sidewalls. My times also got faster with the glued sidewalls.
My fatal mistake/bad decision was swapping for 4 new tires, my first instinct was to keep the 3 that were running great and just swap in the one right rear that had the issue........live and learn.
#3870
1387Likes
