Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-13-2023 | 04:29 PM
  #3586
tony q's Avatar
Originally Posted by Core Creations
Shoot…with all the new hop ups, it may be worth building one from scratch.
what is the difference between the TT02R and D. i want to build a car for TCS GT Pro Spec.
tony q is offline
Old 04-13-2023 | 04:43 PM
  #3587
OVA's Avatar
OVA
The D stand for Drift ..drift tires and other things like skid plate under the chassis ect
TT02R is a good base starter kit for GT Pro
OVA is offline
Old 04-13-2023 | 05:21 PM
  #3588
Core Creations's Avatar
The RR was the car to get but unfortunately I think Tamiya figured it was too good of a deal.
The TT02R will need a few things. My basic list for the R would be:
Hard chassis
Steering upgrade kit
Universals
new sealed diffs
upper camber adjustable arms
6mm hexes
i think that’s probably a good start. Here’s my two rigs…still pushing to improve them all the time. Just got some new parts on the way that Tamiya just released.
Raman likes this.
Core Creations is offline
Old 04-13-2023 | 05:46 PM
  #3589
tony q's Avatar
Hard chassis
Universals
new sealed diffs
6mm hexes
nice
tony q is offline
Old 04-14-2023 | 01:24 AM
  #3590
Stephtruc's Avatar
TT02R is out of stock everywhere, it is worth buying the TT02D and convert it to TT02R?
https://tamico.de/Tamiya-TT-02R-Chassis-Kit-84409-47326
Stephtruc is offline
Old 04-14-2023 | 03:24 AM
  #3591
DirkW's Avatar
Also here: https://www.modellbau-seidel.de/inde...iya&best=47326
Both shops in Germany though, and no idea about cost of international shipping...
The RR was the car to get...
Depending on the rules set (i.e. if allowed) I'd much prefer the SR over the RR, as the suspension on the S type models is vastly superior.
https://tamico.de/Tamiya-47439-TT-02...SR-Chassis-Kit
https://www.modellbau-seidel.de/inde...iya&best=47439
The SRX is also a nice version, but compared to these SR offerings, with over $100 more, too expensive IMO.
DirkW is offline
Old 04-14-2023 | 03:54 AM
  #3592
simple's Avatar
TT-02D (drift spec): includes oil shocks and full ball bearings, and includes a body depending on the kit.
TT-02R also includes the above (oil shocks and bearings), but goes further to also include aluminum drive shaft, steel out drives and dog bones(drive shafts), speed tuned gear parts so you can use any manufacturer spur to properly gear to brushless motors, 3deg rear aluminum hubs, and a few other blue bits.
TT-02R does not include a body, so this suits it well to selecting your own GT preferred body set.
simple is offline
Old 04-17-2023 | 08:36 PM
  #3593
The latest.
angrymelon and Stephtruc like this.
Silverbullet555 is offline
Old 04-18-2023 | 12:07 PM
  #3594
CloseYetFar's Avatar
Questions?? Tamiya TT-02 Type-SRX or Tamiya TT-02 Type-SR
Hey,
I have a Tamiya TT-02 Type-SR new in box. Should I build it up or get the newly released Tamiya TT-02 Type-SRX? Its pretty hard to figure out which kit has better upgrades, they are both pretty similar.
Thanks.
CloseYetFar is offline
Old 04-18-2023 | 12:47 PM
  #3595
DirkW's Avatar
IIRC the SRX uses an updated, newer TC suspension (54886) than the slightly older SR. I'm not sure, but I seem to remember that this newer suspension doesn't work with the droop screws add-on (54638), but I might be mixing this up with something different. Cannot find what shocks are used on the SRX - 50746 are included with the SR, however.
EDIT: Apart from those two uncertainties (not even having the option to set droop by screws would be quite a let-down though, if true, as this is a major setup/tuning aid, which I'd not like to lose and I find it hard to imagine the updated suspension is so superior as to completely compensate for that), IMO the SRX seems to be a little better equipped, be it included parts or small improvements in detail (better front spool, aluminium prop shaft, speed gears, blades on DCJs and universals) - but I've seen price differences of 110€ between the two kits around here... . I sure like the small improvements on the SRX and kinda wish mine had these nifty details, but it's a TT-02 still, and I think I've sunk enough money into mine.
CloseYetFar and Xrayray like this.
DirkW is offline
Old 04-18-2023 | 03:17 PM
  #3596
Stephtruc's Avatar
Questions??
Originally Posted by Stephtruc
Tamiya 51696 (SP1696) Ring Gear Set 40T
Tamiya 51695 (SP1695) Ring Gear Set 39T
Both fit TT-02 ?
If yes what is better for 17.5T stock racing?
Thx
Old 04-18-2023 | 04:03 PM
  #3597
simple's Avatar
simple is offline
Old 04-18-2023 | 08:07 PM
  #3598
RC4LIF3's Avatar
Wanted to add my fun little drifter to this thread!
angrymelon and Rinskie like this.
RC4LIF3 is offline
Old 04-19-2023 | 11:38 AM
  #3599
simple's Avatar
Saw this little note in a recent Tamiya TT-02 variant manual.
Glad to see Tamiya has finally caught on to what most experienced builders have been suggesting for a while now.
Raman likes this.
simple is offline
Old 04-19-2023 | 01:43 PM
  #3600
Raman's Avatar
Best investment I made. awesome tool to uses.
Qatmix likes this.
Raman is offline
