Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 04-28-2019 | 09:04 AM
  #1996
proliteandsc's Avatar
Default Flying dog bones
After a few crashes my front dog bones started to come out. Now they fall out even with a minor collision. Checked suspension and didn't see anything broken or bent. I race in stock class so can't install anything different. Anyone know what part I need to replace to stop it from happening?
proliteandsc is offline
Old 04-28-2019 | 01:50 PM
  #1997
Anyone have a good starting setup for running on black EOS carpet
rippen is offline
Old 04-28-2019 | 02:10 PM
  #1998
Try putting a couple of O-rings on the inside of the cup to keep them more centered.
hobbyten is offline
Old 04-28-2019 | 05:08 PM
  #1999
Tried that. It didn't work.
Something on the suspension is flexing more then it should.
I also tried switching rear cups and dogbone to the front, but it didn't help.
Old 04-28-2019 | 10:30 PM
  #2000
Having the same problem. Getting over it, and want to move on.
Have shimmed the slop out of the front hubs, but not sure what else to do.
Bloke is offline
Old 04-29-2019 | 06:17 PM
  #2001
Hoyle33's Avatar
Finally got everything for my kit, turn to page 1, and see that it says I should have Tamiya Instant Cement for rubber tires.
Is there a alternative to the Tamiya brand that works well so I don’t have to wait a month for it to arrive from Japan?
Hoyle33 is offline
Old 04-29-2019 | 06:27 PM
  #2002
SUPER GLUE!!!
hobbyten is offline
Old 04-29-2019 | 08:35 PM
  #2003
Get any tire glue. It will hold better. Don't forget to clean and scuff the rims and tires.
Old 05-01-2019 | 04:27 PM
  #2004
Hoyle33's Avatar
What about the Hobbywing XR10 Justock Sensored Brushless ESC/SD G2.1 Motor Combo (17.5T) on Amain for $100?
Just got this motor and ESC in the mail, and I assumed that it would come with a 17.5 tooth pinion, which it did not. My TT-02 kit came with a 19 tooth pinion. Will this work?
Hoyle33 is offline
Old 05-01-2019 | 05:28 PM
  #2005
How would you have a half tooth pinion?
Nerobro is offline
Old 05-01-2019 | 05:31 PM
  #2006
Hoyle33's Avatar
Hmmm that’s a good point, I misunderstood what the 17.5T stands for. Will the 19 tooth pinion work?
Hoyle33 is offline
Old 05-01-2019 | 05:34 PM
  #2007
yes, any pinion will "work". 17.5t is how many turns the motor is.
Nerobro is offline
Old 05-01-2019 | 07:42 PM
  #2008
Just got the TT02 to race in the upcoming TCS Pro spec class at TQ in May. I saw the class running at 702 last week and regretted not getting it sooner. Any of you running it by chance?
ebohon is offline
Old 05-02-2019 | 06:10 AM
  #2009
Seems like quite a few are running the tt02 r or rr.
hobbyten is offline
Old 05-02-2019 | 10:27 AM
  #2010
I actually got the RR - seems like its the same as the R except for the blue chassis. It has all the main upgrades but I ordered a few more while staying within TCS rules, like the aluminum steering, motor heatsink, etc. To bad TCS doesn't allow the screw upgrade from the S... not so much for the weight savings but so that I don't have to use a Phillips screwdriver. I'll run this in our local USTG class to see if it is competitive. I'm very new to Tamiya in general. I know they have the 'pro' 419 chassis but that is to expensive for me since i'm in it mostly for fun and as a hobby. Hopefully this TT02 will be good enough to use in the USGT class.
hobbyten likes this.
ebohon is offline
